How do FTP programs work?
Postby hhp 211 on Wed Feb 18, 2004 9:47 pm
Hey, I have some large Jpeg (2560 x 1920) and zip files that I'd like to send to my brothers computer,
I was thinking that an FTP (or P2P) would be the way to go as e-mail takes way too long and I don't want to make the pic size any smaller and loose quality.
So with an FTP program how do I get the files to him or how does he get them from me?
If anyone was wondering I have a Broadband connection and a 2.4GHz cpu
:P
hhp 211
Postby UALOneKPlus on Wed Feb 18, 2004 11:19 pm
With FTP you need some server space to download the files to. Your broadband provider should have provided you with some space.
To get to it, all you need to do is type in "ftp://your_user@your_ISP.com" (double check with your ISP for sure) in the Internet Explorer Address bar, and it will ask for a user name and password, which you should have set up with your ISP.
Then you can just drag and drop the photos onto that space. Give your bro the username and password, and he should be able to see it and copy it to his PC.
Here's some more info:
http://www.computerhope.com/software/ftp.htm
-Danny Kaye
UALOneKPlus
Postby robertb on Wed Feb 18, 2004 11:45 pm
yes this is an interesting question and something I keep pondering over myself.
It occurred to me that for larger files like say 200mb or 500mb then ones own sevice provider would not help?
What about the file sharing programs like e-mule and e-donkey and Kaza.
Presumably if your brother and yourelf both install say e-mule and you offer the said files for sharing and if the file names are only known to both you and your brother then he can download it from you.
I'm certain this would work but there must be a more professional way to do it?
I have also seen a program called www fileshare pro specifically for downloading files direct from someone else's computer but I have not yet tried it.
robertb
Postby UALOneKPlus on Thu Feb 19, 2004 3:34 am
Well, if you really had to share 200mb over the web, you could set up a PC as a file server and allow someone else to ftp to it and download it.
But I'd just burn a CD or DVD and send it to them. Much easier and less risk.
-Danny Kaye
UALOneKPlus
Postby robertb on Thu Feb 19, 2004 9:16 pm
Thats true but broadband is getting more popular and on the standard 512k broadband connection it only takes about one hour to download 200MB which is quick if you are considering whether to post a CD overseas.
The server idea is interesting although I have only so far tried networking two computers together off line. I must read up on this.
robertb
Postby hhp 211 on Fri Feb 20, 2004 3:10 am
I found this sweet program, it's called http://www.hello.com
it's a jpeg p2p/friends program and it works awsome
no compression, can set up for auto save pics, broadband setting, fast, IM chat, etc.
I lucked out in finding this one.
hhp 211
Postby dimitri on Sat Feb 21, 2004 12:55 pm
You can install a ftp server program, make an account for your brother, let him log in, preferably with a ftp client installed and download whatever files you will allow him access to.
A great freeware ftp server is GuildFtpd http://www.guildftpd.com/
A great freeware ftp client is SmartFtp http://www.smartftp.com/
It's possible to do it in reverse, meaning your brother will install the server and you will log in and upload to the account he will make for you.
Remember that the transfer rate from you to him will be limited by your max upload speed and his download speed regardless who runs the server.
All the best, dimitri (a.k.a digi, mango)
digi.rpc1.org | digidvd.tk
LiteOn/Jlms dvd drives: info, firmware, regional freedom :cool:
dimitri
Postby dodecahedron on Sat Feb 21, 2004 3:10 pm
thanks for the links dimitri. :)
nice to see you here again. you don't drop by nearly as often as you used to :(
Postby dimitri on Sun Feb 22, 2004 7:12 am
Cheers Dodecahedron ;)
Yeah, I come less often and whenever I sneak a peek I see that all problems I could have contrinuted to are already dealt with in the best possible way. Lots of knowledgeable and helpful members around!
8)
dimitri
