How to display the actual burning speed in nero 6?
Postby computation on Thu Jul 17, 2003 3:19 am
In nero 5.5 we are able to display the actual spead of burning by modifying the registry table. However in nero 6 that registry entry is not found any more.
Can we still enable it? Thanks.
computation
Postby aviationwiz on Thu Jul 17, 2003 3:29 am
The default in Nero 6 is to see the true writing speed.
Postby computation on Thu Jul 17, 2003 4:01 am
Thanks. Really? When I select a record speed, say, 52x, then during the burning it always indicates "write speed: writing at 52x":(
Edit: I added myself a DWORD entry "ShowSingleRecorderSpeed" to the registry table. Now I can choose "determine the maximum speed" and the real speed is displayed.
computation
Postby govern1 on Mon Jul 21, 2003 12:00 pm
I disagree that the default in Nero 6 is to display the actual write speed. I have Nero 6 Ultra (got at BestBuy a week ago) and it only says "buring at 48X", not the actual speed. Is there a way to change that? To computation, where exactly did you add the DWord? Could you be more specific?
Thanks!
Shawn
govern1
Postby cfitz on Mon Jul 21, 2003 12:13 pm
I don't have 6, but presumably it is the same registry key as in 5.5:
http://www.cdrlabs.com/phpBB/viewtopic.php?t=9476
Specifically, look at this post:
http://www.cdrlabs.com/phpBB/viewtopic. ... 5150#55150
Anyway, it shouldn't hurt to give it a try. You might need to modify the Nero root key if it has been changed to something that reflects Nero 6. For example, it might now say "Nero - Burning Rom 6" instead of just "Nero - Burning Rom". I don't know that it has or has not changed like this, but it would be something to check if the patch doesn't work as is.
Postby govern1 on Tue Jul 22, 2003 6:34 am
Thanks. That worked like a charm. I created the new DWord and set it to "1". No, displays actual real-time burning speed.
govern1
Postby cfitz on Tue Jul 22, 2003 7:20 am
You're welcome.
