How can I burn VCD at write speed 4X or 2X with LG 24x10x40
Postby ltvu on Fri May 02, 2003 4:07 am
I am using Nero Burning Room 5.5.10.20 and LG 24x10x40 CD-RW GCE-8240B. I want to burn my VCD at write speed of 4X or 2X. However, it always starts burning at 8X (minimun speed). How can I lower the write speed ?
ltvu
Postby cfitz on Fri May 02, 2003 8:44 am
You can't. The slowest burning speed your drive supports for CD-R media is 8x. It is a hardware limitation, not a problem with Nero.
