Scour wrote:Hm, i don´t see a really "extreme" performance. It looks like a marketing-gag, it perform like the standard-M5P
IOPs are overratet
Yeah, it is pretty much like the old M5P with the Xtreme firmware. I've seen a lot of reviewers claiming it to be faster than that even, but I just didn't see it. In fact, it was slower in tests like Iometer.
The 100k IOPS are a huge marketing gag. You don't come close to that number during normal usage.
The biggest thing you should take away M5Pro Xtreme is that this will most likely be Plextor's base design moving forward. The PCB is labeled "M6S" so its pretty likely we'll see it used for the next generation as well. I still haven't heard a good explanation for the switch from BGA to TSOP NAND yet. I'm guessing it has something to do with cost. I can't imagine they're saving much since they have to use 2x as many chips.
