help with streaming radios
Postby eliott_tj00 on Tue May 19, 2009 6:19 am
Does anyone have any idea if it is possible to record streaming radios?Have to go away from home for a couple of weeks and I was thinking it would be great to be able to listen to some good music on my phone.
eliott_tj00
Re: help with streaming radios
Postby Ian on Tue May 19, 2009 11:48 am
Audacity (http://audacity.sourceforge.net) is probably your best bet if you're willing to do some work configuring it. Here's a link explaining how to do it:
http://www.brynmawr.edu/llc/help/multim ... oAsMP3.htm
Otherwise here are a couple of good links with other solutions:
http://reviews.cnet.com/8301-12519_7-10031813-49.html
http://radio.about.com/od/recordstreami ... inghub.htm
Postby bluespike on Thu May 21, 2009 5:34 am
Try radiotracker, one of those reviewed in the about.com link from ian. It's easy to use and you don't have much configuring to do, if you're looking for a easy way of doing this.
bluespike
Postby eliott_tj00 on Fri May 22, 2009 5:56 am
Great, thanks.I am going to try the ones recommended here first, although I hope I can manage with the configuration part. Not such a genius in computers.The links also seem pretty promising.
eliott_tj00
