help with NEC ND-3520A dvd burner
Postby iomega04 on Sun Mar 06, 2005 1:55 am
i bought this burner on http://www.newegg.com/app/viewproductde ... 035&DEPA=1
when i try to burn a 52x cd-r....the max it shown is 16x or 8x..even tho the max on this drive should be 48x
when i try to a burn a tdk 8x dvd-r..using nero the max it show is 2x or 4x?
can someone plz help me
iomega04
Postby hoxlund on Sun Mar 06, 2005 4:09 am
what cd-rs are you trying to burn to?
when i burn to my TY 52x cd-r on my 3520, they can go all the way up to 48x
Postby dodecahedron on Sun Mar 06, 2005 4:29 am
Postby Ian on Sun Mar 06, 2005 10:06 am
I would try other media. Just because it says 52x or 8x on the discs doesn't mean the drive supports them at those speeds.
Postby HardwareHarry on Sun Mar 06, 2005 8:54 pm
http://www.de.nec.de/softwareoverview2. ... gid/74|76|
Here the media list from NEC Germany...
Harry
HardwareHarry
