by Inertia on Fri Dec 27, 2002 1:54 am
Post the NeroHistory.log data (in the Nero subdirectory) for a failed burn that resulted in the Communication Failure error.
This error has been associated with a failure to operate properly in UDMA mode. Try setting the burner to PIO mode 4, and if it works this would help to define to problem. If it works in PIO mode 4 make sure that you have enough DMA channels available for use. In Device Manager | Sound, video, and game controllers if SoundBlaster DOS emuation is enabled, disable and remove it. In the system BIOS, if the parallel port is set to ECP, change it to EPP or standard mode. Reenable DMA for the burner and try it again.
This error can also be caused by a bad IDE cable. This would also explain why the error repeats with different drives. Swapping the drives around may appear to fix the problem, but is the cable is bad this just avoids the problem until the connection is used again.
Try replacing the cable with a new one. Try using both a 40 wire and 80 wire cable to see if it makes a difference. Don't try a 40 wire cable for the hard drive, just the burners.
