help with burinng .bin
Postby tyronemoss on Mon Dec 09, 2002 4:22 pm
how do i burn one of those file extensions? (BIN File)...
using Nero Burning ROM version 5.5.9.17...
tyronemoss
Postby Ian on Mon Dec 09, 2002 4:45 pm
go to File->Burn Image.
Choose the cue for the bin file and burn.
Postby tyronemoss on Mon Dec 09, 2002 5:06 pm
yes but it says......
Foreign image settings
->Type Of Image - (data mode 1)(data mode 2)(Audio)(HFS)
->Raw Data - check or uncheck
->Block size (bytes) 2352 - 2048
->Image header (bytes)
->Image trailer (bytes)
->Scrambled - check or uncheck
->Swapped - check or uncheck
what should i do?
also is there a way to convert a .bin file to .nrg .iso or .cue??????
tyronemoss
what should i do?
tyronemoss
Postby Tril- on Mon Dec 09, 2002 9:34 pm
you can ask someone for a cue. or just make one
FILE "yourfile.bin" BINARY
TRACK 01 MODE1/2352
INDEX 01 00:00:00
Unless you know the mode and data block you can just select it when you load the cue in nero.
Or give cd-mate or cdrwin or diskjuggler all of those do .bin files w/o the cue. hopefully nero will do it too later on.
Tril-
Postby mrk1283 on Wed Dec 11, 2002 6:23 am
you don't necessarily need cue files at all with nero, just select teh bin file after clicking "all files" and use burn mode 2 and burn it that is all.
Never has failed me. I use the latest nero too.
mrk1283
