cdrfreak2003 wrote:what is the site for Lame Encoder??
cdrfreak2003 wrote:... and if anybody else knows a site for something that can rip mp3's higher than 320kbps please tell me..
For VBR modes (generally highest quality):
"--alt-preset standard" This preset should generally be transparent
to most people on most music and is already
quite high in quality.
"--alt-preset extreme" If you have extremely good hearing and similar
equipment, this preset will generally provide
slightly higher quality than the "standard"
mode.
For CBR 320kbps (highest quality possible from the --alt-preset switches):
"--alt-preset insane" This preset will usually be overkill for most
people and most situations, but if you must
have the absolute highest quality with no
regard to filesize, this is the way to go.
