First thing i did was upgraded it to a 500A then put the newest firmware 2.0f.
Then I had gotten Princo DVD-R 4X media.
I installed the NTI CD&DVD maker and did simulation 2X and burn at 2X. Simuation works fine then at burn it goes buffer under run...
I installed NERO 6.0 and it gives me a different error
First goes
Burn Process started at 2x(2.760 KB/s)
Sony DVD RW DRU-500A
Power calibaration error
Burn process failed at 2x (2,760 KB/s)
Same thing happens with 4X as well.
The settings I use to write my DATA DVD is
No Multisession Disc
Disc at once with Finalize Disc in Nero. tried with simuation and with out.
and 1 2 and 4x tried all same thing.
Ever tried a different blank. same thing
What is going on ?
Help Help. Is this Burner Dead ?
Can i put the firmware back to it's origional DRU-10A ??
