Help removing defective registry key in XP
Postby JJVilzu on Tue Jan 25, 2005 6:10 am
Hi!
I need help removing a defective key in registry with Windows Xp Home. I am familiar with Registry and editing it, but this is new:
I have a key that tells error opening key when trying to access it. The key key seems to be damaged somehow and i need to remove it but canoot do ANYTHING with it, not even view it. Is there any way to force a "broken key" away from registry? Thanks in advance!
JJVilzu
Postby eliminator on Tue Jan 25, 2005 6:24 am
Try the Regseeker, see if it helps...
http://www.hoverdesk.net/freeware.htm
Wake up ATI :-)
eliminator
Postby dodecahedron on Tue Jan 25, 2005 7:35 am
what is that key's name ?
Postby JJVilzu on Tue Jan 25, 2005 7:54 am
Thank you Eliminator.
But sorry to say: no help. I´ve tried RegCleaner and several other registry editor/cleaner programs, but that does not change the fact, that the key is totally unusable and i don´t think that any program that cleans or edits the registry changes this thing. These programs do find this key and i can dlete it, but it does not disappear from registry.
This problem needs something more powerfull to be solved...
JJVilzu
Postby dodecahedron on Wed Jan 26, 2005 4:02 pm
again i ask, what is the registry key ?
Postby eliminator on Wed Jan 26, 2005 7:38 pm
yup, the key would help ! :D
Wake up ATI :-)
eliminator
