help nero vision freezes wen tryin to create chapter marks
Postby coopsvip on Sat Apr 29, 2006 5:29 am
can sum1 help plz? nero vision freezes when tryin to create chapter marks? after about 10/15 mins starts to work again but the chapter marks are jus blank boxes or they have the nero sign in em and wen i try to preview it jus freezes or plays a blank screen. im using the very the latest nero version and have tried with all the nero 7 versions but no joy.any ideas how to fix?
coopsvip
Postby burninfool on Sat Apr 29, 2006 12:30 pm
Go back to a previous version,all I have been reading lately is the latest version takes 5 minutes to load and locks up.
Postby CCampbell on Mon May 01, 2006 4:53 pm
It's true that Nero Vision is taking a long time to launch. This is a problem we had with Nero Vision a year or more ago. I'm creating a Bug Entry for this 'extremely' long delay in launching Nero Vision, and I hope the cause is the same as last time, as if it is, it should be a quick resolution.
As for problems with Chapter marks, I'm not seeing that here, but I only did a quick test with a 200MB source file and 12 chapter points.
What size is your source file, and how was it created?
How many chapter points are you creating?
Did you create them manually, or did you use the Auto Detect feature in Nero Vision to create them?
The more information I have, the better chance I have of duplicating your symptoms.
Postby coopsvip on Sat May 06, 2006 1:46 pm
CCampbell wrote:It's true that Nero Vision is taking a long time to launch. This is a problem we had with Nero Vision a year or more ago. I'm creating a Bug Entry for this 'extremely' long delay in launching Nero Vision, and I hope the cause is the same as last time, as if it is, it should be a quick resolution.
the file was 700mb avi and i was using auto detect.
coopsvip
Postby chronoxiong on Tue May 09, 2006 6:49 am
guys, i am having problems wit Nero Vision too. i am using the latest version and i am having too much problems with it. the program freezes on me whenever i try to make Chapter marks now. i used to have no problems with it before. whats going on here? oh yea, i am using 24 minute TV episodes that i converted in Vob files. wat gives?
chronoxiong
Postby CCampbell on Wed May 17, 2006 4:28 pm
Ok, I was able to duplicate this issue with one of my source files that was 700MB in size, give or take a few MB.
One thing I noticed when I used the Auto Generate feature, when I scrolled through the chapters it had generated, a few of them had a 'white' box with an X in it, instead of a thumbnail for the chapter point.
If I deleted the affected chapter points, I was able to burn without problems. If I left the affected chapter points alone, it would fail to burn.
And if I tried to select the chapter point and then move it frame by frame to try and obtain a thumbnail at a different location, Nero Vision locked up.
I need to do some more testing and test with different source video files before I can generate a bug report, as I need to cover all the angles, but this may be the same issue you are running into.
Check and see if the chapter points you automatically generate of this same issue.
Postby chronoxiong on Thu May 18, 2006 1:35 am
CCampbell wrote:Ok, I was able to duplicate this issue with one of my source files that was 700MB in size, give or take a few MB.
NeroVision still locks up on me whenever i try to move from frame to frame. this is really annoying. i've read from other forums that we should all go back to an earlier 7.0 version which i am thinking of doing. i like NeroVision so much since it is easy to create menus, chapters, and even put music in too but this issue has really angered me. i also want to point out that i recently got the CS2 versions of Adobe programs into my comp and i thought those were the cause of NeroVision locking up but i dont think it is now. :cry:
chronoxiong
