Just bought the NU DDW061 yesterday. Maybe I am too confident in the wide-spread 8x trick. Without burning any CDR/DVD+R, I simply downloaded the 6xto8x.exe & firmware bx30 and upgrade it. Reboot the machine, I am glad to see that I get the DDW081. But unfortunately, many problem come up ....
(1) I used the bundled MyDVD and Verbatim 4X DVD+R to do a test. Try drop and burn a 3G MPG2 video. Prompted "write error" after burned ~8%.
(2) Try Nero 6.0.x and burn with another Verbatim 4X DVD+R. Nero complaints "Recorder command not supported" and refuse to burn.
(3) Upgraded Nero to 6.3.x, the latest one. Try run CDSpeed. It compaints that "Simulation not supported on this type of media". Check in Nero, the simulation checkbox is also disabled. Oh ! God.
(4) OK, I simply dropped the 3G avi to Nero and select DVD Rom format. Nero said that file size > 2G cannot be supported. Select DVD ROM (UDF) and try again, Nero starts to burn but like MyDVD, prompts error "write error" at ~8 to 10%. Surprise enough, it does not eject the disc but go on. The drive's LED keeps red and green, lasts more than 10 minutes and I need to reboot the machine.
(5) Sigh. Try burn CDR. Before inserting any CDR, Nero displayed 40X CDR burn is supported. Insert a 52X CDR, 40X turns to be 32X immediately.
Anyone can kindly help ? I just want to burn a DVD with no error
Miho
