Help: Identify DVD writer
Postby Halc on Sun Nov 25, 2007 7:24 am
Hi guys,
I'm trying to locate a DVD burner (external) for OS X / Windows -mixed use:
- external
- firewire (1394a is ok) + USB 2.0
- quality in reading (high jitter, low reflectance, scratched discs)
- quality writing to quality media (better MCC, TY, MXL Made in Japan, etc)
BY/DIY options (buy casing, buy internal, mix together) are out of option as these guys don't know how to do it and I don't have the time.
So, I'm looking at:
LaCie d2 18x DVD±RW with LightScribe
http://www.lacie.com/uk/products/product.htm?pid=10908
LaCie d2 20x DVD±RW with LightScribe
http://www.lacie.com/uk/products/product.htm?pid=11005
but I have trouble identifying the drives they use from the specs (and I don't trust the photos, they could be from some earlier models).
Anybody able to tell which drives are likely to be inside those LaCie models?
Halc
Postby Halc on Mon Nov 26, 2007 4:39 pm
Anyone?
I thought this was too easy for you guys :)
Halc
Postby Ian on Mon Nov 26, 2007 5:16 pm
I forgot what they were using. I want to say NEC or Samsung.
Postby Ian on Mon Nov 26, 2007 5:20 pm
Postby Halc on Wed Nov 28, 2007 6:06 am
Thanks Ian!
That is a sort of a relief. I'll recommend the 20x version and a quality disc that fits the model. I'll report the actual model here for other's benefit, if I find it out for myself.
Halc
