HELP! How to burn many movies on a single dvd9?
Postby jsonvega on Mon Sep 24, 2007 9:12 pm
i like to burn my downloaded anime series, i want to fit like 16+ episode in 1 dvd, how will i do that? normally, the avi's size is 170mb, i only can burn like 12 to 14 episode in one dvd9. Im just wondering how the pirating industry can make a 27 in 1 naruto series, or 25 in 1.
anybody knows how to do that? and what softwares to use? plz help! thanx
jsonvega
Re: HELP! How to burn many movies on a single dvd9?
Postby Ian on Mon Sep 24, 2007 11:58 pm
jsonvega wrote:Im just wondering how the pirating industry can make a 27 in 1 naruto series, or 25 in 1.
They usually sacrifice bit rate or resolution to do that.
Most consumer grade video editing software will do what you want. For example, Nero Vision will let you add a bunch of videos and then choose the disc size. It will automatically reencode the videos so that they fit.
