drive: Toshiba SD-R2102 8x write CD-RW/DVD combo drive internal (brand new)
media: Sony CD-R
computer: Compaq Presario 705US laptop; 1.0GHz AMD Athlon; 256MB RAM
OS: Windows XP Home Edition (newly reformatted/reinstalled)
Burning software: Nero 5.5.9.14
I'm really frustrated by this problem. It seems that only every other burn is successful. I tried it w/three different audio CDs and every other burn worked. Although, at the end of each burn, Nero told me the CD was burned successfully.
The CDs all worked fine when played on the computer, but when I tried to play them on two different CD players (one standard CD player, one CD-R/CD-RW/MP3/WMA compatible), the burns that didn't work just skipped repeatedly on the first two or three tracks. All successive tracks played fine.
A peculiar feature about the CD-Rs that didn't work is that you can visibly see a "cloudy" ring emanating maybe a 1/2 inch from the center of the CD (on the burned side), which I presume is why the first 2-3 tracks skip.
It's odd that every other CD works consistently. One will work, the next won't, and so on.
I am burning at 8x. I tried turning Buffer Underrun Protection off to solve the problem, but it did the same as before. One good, one bad. I am not multitasking while burning.
Does anyone know what could be the matter? I would greatly appreciate a solution. Thank you.
-dima
