Help me Decide which DVD Burner to get for Backup.
Postby goden99 on Thu Sep 22, 2005 5:18 pm
I need a DVD burner that key factor is DVD- or DVD+ Writing quality (Preferably -). Its mostly going to be used in a buisness for backing up all their data once a week.
These are the ones I can get easly and fit the price range. What do you guys recommend from the list below ?
Pioneer DL110
LG 4163B
LG 4165
LITEON SOHW-1693S
BENQ DW1640
goden99
Postby dolphinius_rex on Thu Sep 22, 2005 5:59 pm
Postby goden99 on Thu Sep 22, 2005 7:25 pm
Thanks dolphinius_rex.
I guess the Benq is best choice for quality :)
goden99
Postby CowboySlim on Thu Sep 22, 2005 11:58 pm
10-4, to that Rex.
I don't stay home with out one.
Be sure to wear a Zapatopi when using it to rip. The media may contain subliminal mind control radiation.
Re: Help me Decide which DVD Burner to get for Backup.
Postby frank1 on Fri Sep 23, 2005 12:30 am
goden99 wrote: . . .
For this usage I recommend without hesitation to use DVD-RAM !
Read for example this articles:
" Study says DVD-RAM provides safest bet for data storage "
http://www.cdfreaks.com/news/9765
" Think twice before you write once "
http://www.storagesearch.com/pegasusart3.html
Burners on the market that can burn DVD-RAM are for example:
LG 4163
LG 4167
Pioneer 110
Nec 4550
Panasonic LF-M821
This last one can even burn DVD-RAM in a protective cartridge ( so no fingers, dust or scratches on it)
See also what they say in this recent review of the LG 4167B:
http://www.cdrinfo.com/Sections/Reviews ... &PageId=20
« DVD-RAM media is the most appropriate media for large file storage and recovery, since it combines an error correction system and BCM (Bismuth Coupling Material) recording layer technology, which improves signal to noise ratio for higher reliability during high-speed recording.
As Maxell stated: "DVD-RAM is an advanced recording media format that offers a range of digital data applications. Its phase-change recording material allows discs to be re-recordable and erasable, and a superior defect management system ensures accurate recording and playback. DVD-RAM allows instant, random access to any location on the disc for fast and easy data reading and writing. Because DVD-RAM supports fast formatting and no finalizing, it is an extremely easy-to-use media. And with DVD-RAM, changes can be made directly on the disc without the need to transfer data to a hard drive first, speeding up the editing tasks..." »
frank1
