Hard drive problems
Hard drive problems
Postby ruderacer on Sat Mar 26, 2005 4:09 am
I have a WD 200 GB hard drive that is going bad. I contacted WD and received a replacement two days later.
The question is: How do I swap all files and OS to the new one? Or should I perform a clean install of the OS and then copy the rest using the WD utility?
All imput is welcomed.
TIA
RR
"It's the voyage that counts, not the totality of life".
Every Saint has a Past! Every Sinner has a Future!
ruderacer
Re: Hard drive problems
Postby Bhairav on Sat Mar 26, 2005 4:39 am
ruderacer wrote:I have a WD 200 GB hard drive that is going bad. I contacted WD and received a replacement two days later.
TIA
RR
Clean OS > all! Do it, Ghost an image and back up to DVD and CD. Copy the rest using the WD utility.
