LG GSA-H22N write issues
Postby g8m3rtag on Fri Jan 12, 2007 4:59 pm
i was burning some backups on memorex 16x discs at 16x. ran out of discs on that spindle and opened another spindle of memorex 16x discs and started burning to one of them and it was only burning at 4x.
after trying a different spindle of discs it would only burn at 4x on those ones as well. ive downloaded and updated to the 1.01 firmware in these forums and it will still only let me burn at 4x.
i put the same disc in a pioneer 111d (in a different computer) and it will burn at 4x,6x,8x,12x, and 16x but in this LG it only burns at 4x. i find this strange since originally it was burning at 16x.
any idea how to get it to burn at 16x again? im using nero 6, and have tried nero 7.
g8m3rtag
Postby Ian on Fri Jan 12, 2007 5:29 pm
It sounds like the first and second spindles were manufactured by different companies.
Can you tell us the MID for the discs? Use CD Speed (www.cdspeed2000.com) and click on Disc Info tab. From there, you can see the actual manufacturer and MID.
I'm guessing these are Memorex 16x DVD-R and that the second spindle are manufactured by Ritek. For some reason, the GSA-H22N does not write to RITEKF1 at anything faster than 4x.
Postby 2Dogs on Fri Jan 12, 2007 5:37 pm
You might try going to the "Nero Toolkit" and using the "Nero CD-DVD Speed" utility. From version 4.0 and up of that utility there's a check for the Disc Info.
If you need to download the latest version of CD-DVD Speed, it can be found here:
http://www.cdspeed2000.com/
Try running the Disc Info check on the disc you were able to write to at 16x, and then again on the discs to which you could only write at 4x. It's possible the media is actually different, even though it all may be marked as Memorex 16x.
Here's a shot of the test on one of my old Memorex 4x +RW disks. The media type shows as PHILIPS 041 000 (00)
Oops! Ian beat me to the post!!
2Dogs
Postby g8m3rtag on Fri Jan 12, 2007 5:44 pm
the MID on the old discs is CMC MAG. AM3 and on the new ones its RITEKF1.
edit: how are those new sata dvd writers that are around $30 on newegg. if i cant burn these 100 discs i have at 16x im just gonna buy a new burner.
edit: found another pack of em. there riteks to. what burner do you guys recommend, i would prefer a sata one and no more then like $45. internal as well.
g8m3rtag
Postby 2Dogs on Fri Jan 12, 2007 7:54 pm
Just check out the comprehensive burner reviews on this site.
I'm not saying they're your best choices, but the AOpen DSW1812P wrote to RitekF1 media at 16x, as did the ASUS DRW-1608P3S, Samsung SH-S182D, Sony DRU-830A for starters.
You'd probably get some of the above for around $30 at Newegg
2Dogs
Postby Ian on Fri Jan 12, 2007 9:21 pm
There really aren't too many SATA drives out there. Looking at Newegg, you have ones from Lite-On, Samsung and Plextor. I've used the ATA version of the Plextor and its a great drive, but for what they're asking, you could buy 2 or 3 of the others. I have a few of the Lite-Ons, but I haven't used them enough to say whether or not they're decent or not. The Samsung? Still waiting for them to send me a test unit.
Postby zhadoom on Sat Jan 13, 2007 9:43 am
g8m3rtag wrote:the MID on the old discs is CMC MAG. AM3 and on the new ones its RITEKF1.
RITEKF1 is only supported at 4x in the firmware of H22N.
Looks like Panasonic based LG drives suffer from a lack of support for recent medias. RitekF1 only 4x, ProdiscR05, DaxonAZ2 and Daxon008S aren't supported and fallbacks to 4x.
zhadoom
Postby Ian on Sat Jan 13, 2007 11:36 am
The odd thing is, RITEKF1 is listed in the firmware. If you fire up MCSE and open the 1.01 firmware you see:
Code: Select all
RITEKF1         16x,12x,8x,4x,2x
It must not be identifying it correctly. Either that, its a different revision.
Postby ala42 on Sat Jan 13, 2007 1:47 pm
Ian wrote:The odd thing is, RITEKF1 is listed in the firmware. If you fire up MCSE and open the 1.01 firmware you see:
Code: Select all
... or you did not uses the latest MCSE version :). Older versions displayed the media speed which is stored in the media table, but not the speed supported by the write strategy of the firmware. When figuring out how 18x write speed was encoded, I stumbled over the write strategy tables, which contain the supported write speed. The current display should be accurate.
Code: Select all
MCSE Changelog
1.0.9.5 07 Jan 2007
        - improved support for LG Panasonic MN103 chipset drives
          LG 4164/4166/H20/H21/H22/H31
          - added lossless strategy swapping
          - write speed information is taken from write strategies now,
            so it should match reality
          - added riplock patch
          currently tested on H22N drives only
          Special thanks to 2601, crossg, MegaDETH, zhadoom for the tests.
ala42
Postby Ian on Sat Jan 13, 2007 2:30 pm
Thanks ala42. I was still using 1.0.9.3. Does this new version show the 20x writing speeds with Lite-On's new drives? I don't think it did with 1.0.9.3.
Postby ala42 on Sat Jan 13, 2007 3:37 pm
It does. Please check if the lists are ok and that MCC 03RG20, RITEKF1, MXL RG04 and DAXON016S are supported at 16x only with Overspeed burning disabled on LL05.
LH-20A1P KL05 18x/20x media
Code: Select all
+R
CMC MAG  M02-000 18x,16x,12x,8x,6x
DAXON    AZ3-000 18x,16x,12x,8x,6x
MBIPG101 R05-001 20x,18x,16x,12x,8x,6x
SONY     D21-000 18x,16x,12x,8x,6x
TDK      003-000 18x,16x,12x,8x,6x
YUDEN000 T03-000 20x,18x,16x,12x,8x,6x
-R
CMC MAG. AM3    20x,18x,16x,12x,8x,6x
DAXON016S       18x,16x,12x,8x,6x
MXL RG04        18x,16x,12x,8x,6x
SONY16D1        20x,18x,16x,12x,8x,6x
TTH02           18x,16x,12x,8x,6x
TYG03           20x,18x,16x,12x,8x,6x
LH-20A1H LL05 18x/20x media
Code: Select all
+R
-R
ala42
Postby Ian on Sat Jan 13, 2007 6:49 pm
Yeah, that looks right. It blows my mind that Lite-On would support CMC MAG. AM3 at 20x but limit MCC 03RG20 to only 16x.
Users browsing this forum: Google [Bot] and 1 guest
