LG GH22LP20 + LG GH22LS30 Problems
Postby plopper on Tue May 05, 2009 8:09 am
Hi everybody, I want to ask for your help please as I'm having REAL problems with there two drives.
Everything seems to be fine except the copying/ripping of the DVDs I get out of my DVD recorder I use for recording TV/Sky.
I have a Sony RDR-GX120 recorder which I use to record and edit mostly Motorbike races. When wanting to back them up to DVD-R after recording them I put them into the PC and before getting these two new drives just did a straight disc to disc copy using AShampoo Burning Studio 6 FREE.
That did an exact copy to DVD-R or DVD+RW and was fine.
Now almost every time I try the disc will copy, and the file structure is there, but all the files have 0 file size?
So far I've tried disc to disc copy and ripping the disc to HDD then write it. I've tried writing to DVD-R (Tevion and Verbatim), and two differnt makes of DVD+RW (Mr. DVD and Verbatim).
I've also tried AShampoo, Nero 7 Essentials that came with the drives and CDBurnerXP.
I have XP Pro running Service Pack 2,
Intel Core 2 Quad Q6600,
4 gb RAM.
Any help will be great.
plopper
Re: LG GH22LP20 + LG GH22LS30 Problems
Postby Ian on Wed May 06, 2009 4:18 pm
Are you copying on the fly, from one drive to another?
Postby plopper on Wed May 06, 2009 5:07 pm
Yes that is why I am having all the problems, I have been able to get around some of the problems with either making a disc image first, letting the program cache copy or just copying the Video directory over and then re-authoring the DVD through something live Nero, but really that is not the point is it? Why pay good money for two new Re-Writer drives and them not being able to do what you what then to do most?
I have tested everything else I can think off to do like write CDs/DVDs, ripping converting and everything else seems fine. It's just this one aspect of the drives that is at fault.
plopper
Postby Ian on Wed May 06, 2009 7:24 pm
I'm not sure about non-CSS protected DVD videos, like the ones from your DVD recorder, but those LG's rip commercial discs at only 6x. You may want to run a transfer rate test with CD Speed and see what speeds your reader is capable of and then adjust the writer to match.
Postby plopper on Thu May 07, 2009 3:47 pm
With the DVD+RW discs it's as slow as 2.4x and can't go any slower, so that is just not an option?
Since my last post I've tried the drives out on everything else I can think of and it all works fine, if somewhat noisy at times. So it's just down to this copying on the fly of DVD+RW discs from my recorder!
I must say that even though these drives have recieved some good reviews I personally think they are total, well I can't say, lets say crud?
While trying to sort some things out I put in an OLD DVD-ROM drive (2003) I have knocking about the place a lovely Plextor and the overall performance and especally build quality is FAR better on the old Plex than the LGs. I must have ran the Plex for about 5 years and it STILL works faultlessly every time. The LGs have already TWICE read the disc like there was a bag of spanners in the drive.
Anyway thanx for your thoughts so far, anything else you can think of. For a start is there another make of drive to replace these LGs as I don't think I can put up with them for much longer? The two I replaced were Pioneer 115 and a 116, these lasted just over a year!
I'm not too worried about speed, anything about 8x would be a plus, but it has to be very well built and a bit of a work horse, OH! and BLACK!
plopper
Postby Ian on Thu May 07, 2009 5:10 pm
It's going to be hard to find one to match the quality of an old school Plextor. Most drive companies are trying to cut costs so they use cheaper materials. As a result, they don't last very long.
Optiarc and Pioneer still make some decent drives. Then again, I've been pretty happy with LG as well, so they might not live up to your expectations either.
Postby plopper on Thu May 07, 2009 5:15 pm
Very true, I've not really seen a drive in the last couple of years that I would personally call robust!
plopper
Postby Dartman on Thu May 07, 2009 9:43 pm
If all you really want to do is rip on the fly from one drive to the other you might want to try one of the newer Samsung drives with the riplock removed firmwares available at CD freaks and others maybe. They will rip most regular DVD's at 18x and DL at 16x I think, not sure how fast they are at rewritables but probably faster then your getting now.
You could pair it up with one or both of the LG's you have now and be able to do on the fly a lot faster.
If it's mission critical I let it make a image first, just way safer method but it is nice on normal stuff to save time and just rip/burn as fast as possible in one step.
I remember doing the same thing back when CD writers were SCSI and pretty new. I ended up finally with a Yamaha 4260 and a Plextor 32x reader as it was the fastest cd rom
drive out there for DAE and could rip at 32x speed, way faster then the Yamaha could burn. I later got a 40 wide then a LiteOn 163 DVD rom reader as it was even faster and IDE for cheap. I think all of those are still here somewhere and work.
IDE finally got cheap and fast enough that all the SCSI based drives went away, now we're doing SATA 8)
Postby sa1time on Wed Sep 02, 2009 1:48 pm
Hi there folks
Not sure if anyone could possibly assist me with my quandry :)
I have recently purchased the above make of drive however when attempting to make backups of my original games, I have been faced with the following issues.
I have recorded the log and seriously hope that you guys or girls could help me out.
Thanks in advance,
Grant
I 17:16:15 ImgBurn Version 2.5.0.0 started!
I 17:16:15 Microsoft Windows Vista Ultimate Edition (6.0, Build 6001 : Service Pack 1)
I 17:16:15 Total Physical Memory: 3,134,888 KB - Available: 1,689,792 KB
W 17:16:15 Drive C:\ (FAT32) does not support single files > 4 GB in size.
I 17:16:15 Initialising SPTI...
I 17:16:15 Searching for SCSI / ATAPI devices...
I 17:16:16 Found 1 DVD±RW/RAM!
I 17:16:46 Operation Started!
I 17:16:46 Source File: E:\Wii Games\Far Cry Vengeance.iso
I 17:16:46 Source File Sectors: 2,294,912 (MODE1/2048)
I 17:16:46 Source File Size: 4,699,979,776 bytes
I 17:16:46 Source File Volume Identifier: Far Cry Vengeance
I 17:16:46 Source File File System(s): Special
I 17:16:46 Destination Device: [0:1:0] HL-DT-ST DVD-RAM GH22LP20 1.03 (D:) (ATA)
I 17:16:46 Destination Media Type: DVD-R (Disc ID: ISSM R02) (Speeds: 4x, 8x, 12x, 16x)
I 17:16:46 Destination Media Sectors: 2,298,496
I 17:16:46 Write Mode: DVD
I 17:16:46 Write Type: DAO
I 17:16:46 Write Speed: 4x
I 17:16:46 Link Size: Auto
I 17:16:46 Lock Volume: Yes
I 17:16:46 Test Mode: No
I 17:16:46 OPC: No
I 17:16:46 BURN-Proof: Enabled
I 17:16:46 Filling Buffer... (40 MB)
I 17:16:59 Writing LeadIn...
I 17:17:15 Writing Session 1 of 1... (1 Track, LBA: 0 - 2294911)
I 17:17:15 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2294911)
I 17:31:29 Synchronising Cache...
I 17:31:59 Exporting Graph Data...
I 17:31:59 Graph Data File: F:\Users\Grant\AppData\Roaming\ImgBurn\Graph Data Files\HL-DT-ST_DVD-RAM_GH22LP20_1.03_02-SEPTEMBER-2009_17-16_ISSM_R02_4x.ibg
I 17:31:59 Export Successfully Completed!
I 17:31:59 Operation Successfully Completed! - Duration: 00:15:13
I 17:31:59 Average Write Rate: 5,374 KB/s (3.9x) - Maximum Write Rate: 5,610 KB/s (4.1x)
I 17:31:59 Cycling Tray before Verify...
W 17:32:09 Waiting for device to become ready...
I 17:32:20 Device Ready!
I 17:32:21 Operation Started!
I 17:32:21 Source Device: [0:1:0] HL-DT-ST DVD-RAM GH22LP20 1.03 (D:) (ATA)
I 17:32:21 Source Media Type: DVD-R (Book Type: DVD-R) (Disc ID: ISSM R02) (Speeds: 4x, 8x, 12x, 16x)
I 17:32:21 Image File: E:\Wii Games\Far Cry Vengeance.iso
I 17:32:21 Image File Sectors: 2,294,912 (MODE1/2048)
I 17:32:21 Image File Size: 4,699,979,776 bytes
I 17:32:21 Image File Volume Identifier: Far Cry Vengeance
I 17:32:21 Image File File System(s): Special
I 17:32:21 Read Speed (Data/Audio): MAX / MAX
I 17:32:21 Verifying Session 1 of 1... (1 Track, LBA: 0 - 2294911)
I 17:32:21 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 2294911)
W 17:38:35 Failed to Read Sector 2255520 - Reason: Unrecovered Read Error
E 18:13:37 Failed to Read Sector 2255520 - Reason: Unrecovered Read Error
E 18:13:37 Failed to Verify Sectors!
I 18:13:41 Exporting Graph Data...
I 18:13:41 Graph Data File: F:\Users\Grant\AppData\Roaming\ImgBurn\Graph Data Files\HL-DT-ST_DVD-RAM_GH22LP20_1.03_02-SEPTEMBER-2009_17-16_ISSM_R02_4x.ibg
I 18:13:41 Export Successfully Completed!
E 18:13:41 Operation Failed! - Duration: 00:41:16
I 18:13:41 Average Verify Rate: 1,821 KB/s (1.3x) - Maximum Verify Rate: 21,898 KB/s (15.8x)
sa1time
Postby Ian on Wed Sep 02, 2009 3:16 pm
The verify fails? Does the game still play though? I'm not familiar with the DRM on Wii games so I'm not sure if this is normal or not.
Postby sa1time on Wed Sep 02, 2009 3:50 pm
No the game reflects as not being able to be read by wii.
Problem is my kids think that dvd's and cd's make good frisbees too, so i somehow need to get this sorted :)
sa1time
Postby Ian on Wed Sep 02, 2009 3:53 pm
I'd try other discs. Going by the MID (ISSM R02), those discs are Great Quality brand... which are anything but great quality.
Postby sa1time on Wed Sep 02, 2009 3:57 pm
kewl cheers for your help will have a go with that
Keep you posted
sa1time
