LG GGW-H20L bd burning error pls help.
Postby eternalkp on Thu May 15, 2008 10:36 am
Hi guys.
this is my current system.
AMD FX60 dual core cpu.
Asus A8N-SLI skt 939
3gb of pc3200 ram
150gb raptor 10k rpm
500gb seagate
500gb seagate
8800GTS G92 gpu
creative fatal1ty sound card.
Dell 30inch monitor.
Windows XP SP3 Professional x86
Nero burning rom 8 ultra.
I want to experiece HD so i bought a LG GGW-H20L.
this drive is supposed to be able burning bluray @ 6X max.
and i read a review of this drive in cdrlabs.com and they can get this drive to burn the verbatim bluray disk @ 6x in about 18min, 22min in pcworld.com
My speed is now way near this. a 25gb takes about an hour or so. I have 3 coasters already. each time with an error message of: Invalid Block Address. and everytime it fails to burn a bluray disk, my system freezes...one core of the cpu is 90% while the other one is idle.
I use Nero 8 ultra...pls help.
i save the nero error log. this is what it reports:
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.3.2.1
Internal Version: 8, 3, 2, 1
(Nero Express)
Recorder: <HL-DT-ST BD-RE GGW-H20L>Version: YL03 - HA 1 TA 1 - 8.3.2.1
Adapter driver: <Serial ATA> HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: <LITE-ON DVDRW LH-20A1H >Version: LL0B - HA 1 TA 0 - 8.3.2.1
Adapter driver: <IDE> HA 1
=== Scsi-Device-Map ===
CdRomPeripheral : LITE-ON DVDRW LH-20A1H nvata Port 0 ID 3 DMA: Off
DiskPeripheral : ST3500641AS nvata Port 1 ID 0 DMA: Off
DiskPeripheral : ST3500630AS nvata Port 1 ID 2 DMA: Off
DiskPeripheral : WDC WD1500ADFD-00NLR0 nvata Port 2 ID 0 DMA: Off
CdRomPeripheral : HL-DT-ST BD-RE GGW-H20L nvata Port 2 ID 2 DMA: Off
=== CDRom-Device-Map ===
LITE-ON DVDRW LH-20A1H D: CdRom0
HL-DT-ST BD-RE GGW-H20L E: CdRom1
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Physical memory : 2047MB (2097151kB)
Free physical memory: 2047MB (2097151kB)
Memory in use : 21 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
15.5.2008
UDF compilation
9:09:19 AM #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
9:09:20 AM #2 Text 0 File Isodoc.cpp, Line 6713
UDF document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : pure
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
9:09:20 AM #3 Text 0 File Burncd.cpp, Line 3568
Turn on Disc-At-Once, using Blu-ray Disc media
9:09:20 AM #4 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator 'CUDFSettingsValidatorBD'
ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
Changing UDF revision from '1.02' to '1.02'
9:09:21 AM #5 Text 0 File DlgWaitCD.cpp, Line 311
Last possible write address on media: 11826175 (2628:02.25, 23097MB)
Last address to be written: 11700799 (2600:10.49, 22853MB)
9:09:21 AM #6 Text 0 File DlgWaitCD.cpp, Line 323
9:09:21 AM #7 Text 0 File DlgWaitCD.cpp, Line 2932
Recorder: HL-DT-ST BD-RE GGW-H20L, Media type: BD-R (seq)
9:09:21 AM #8 Text 0 File DlgWaitCD.cpp, Line 497
9:09:21 AM #9 Text 0 File ThreadedTransferInterface.cpp, Line 754
0: TRM_DATA_MODE1 ()
original disc pos #0 + 11700800 (11700800) = #11700800/2600:10.50
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 11700800 blocks [E: HL-DT-ST BD-RE GGW-H20L]
9:09:21 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 956
Prepare [E: HL-DT-ST BD-RE GGW-H20L] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 23963238400, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 11700800 | 0 | 0x00
11700800 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
9:09:21 AM #11 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
9:09:21 AM #12 Text 0 File Burncd.cpp, Line 4359
Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
9:09:21 AM #13 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
9:09:21 AM #14 Text 0 File Burncd.cpp, Line 4481
Cache writing successful.
9:09:21 AM #15 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
9:09:21 AM #16 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 6x (26,970 KB/s)
9:09:21 AM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2673
9:09:21 AM #18 Text 0 File Cdrdrv.cpp, Line 10164
---- Disc Structure (BD): Disc Information on BD (00h) ----
Media Type: 1, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 4098
--- Header ---
Disc Information Identifier: <DI>
Disc Information Format: 01 h
Number of DI Units/Aux Frames in each DI block: 2
Number of (recording) layer to which this DI Unit applies: 0
DI unit Sequence Number in DI Block: 0
Continuation flag: Next DI Unit is the start of a new set of parameters (0)
Number of DI bytes in use in this DI unit: 98
--- Body ---
Disc Type Identifier: <BDR>
Disc Size/Class/Version: 1
DI Unit Format dependent contents:
BD Structure: 18 (12 h):
1 recording layer (SL), BD-R
Hybrid Disc identifier/Channel bit length: 1 (1 h):
no DVD layer present, no CD layer present
channel bit length of 74,5 nm (25.0 GB max. per layer)
Push-Pull polarity flag bits: 00 h
Recorded mark polarity flag bits: 00 h
BCA descriptor: BCA-code present (1)
Maximum transfer rate needed by the application: 0 Mbit/s
Data zone allocation:
First Physical ADIP Address of the Data Zone of the related layer (FAA): 00020000 h (131072)
Last Physical ADIP Address of the Data Zone of the related layer (LAA): 00194E7E h (1658494)
Recording velocities:
Nominal Recording Velocity: 4.92 m/s (1EC h)
Maximum Recording Velocity: 4.92 m/s (64 h -> 100/100)=1
Minimum Recording Velocity: 4.92 m/s (64 h -> 100/100)=1
12 01 00 00 01 00 00 00 - 00 00 00 00 00 02 00 00
00 19 4E 7E 01 EC 64 64 - 2D 2D 2D 2D 23 23 23 23
00 00 00 00 5A 6C 74 04 - 04 43 1C 96 90 F8 F8 F8
F8 00 00 00 00 08 08 08 - 08 50 00 50 00 50 00 50
00 50 00 50 00 50 00 50 - 00 50 00 50 00 50 00 50
00 90 90 B0 C8 E0 00 00
--- Trailer ---
Disc Manufacturer ID: 56 45 52 42 41 54 h <VERBAT>
Media Type ID: 49 4D 61 <IMa>
Time Stamp [m:y]: 0 : 0000 (00 00 h)
Product Revision Number: 0
9:09:50 AM #19 Text 0 File BD.cpp, Line 520
Format BD-R with Format Type 0h, sub-type 1, spare area size 0 -> return code 0
Allocated spare area size on disc 196608
Reserved Track size: 11700800 sect (B28A40h, 22853MB) -> return code 0
BD: Start write address at LBA 0, Recording mode: unknown Recording Mode (0),
spare area allocation: allocation (1), Stream recording: NO (0); return code 0
9:09:53 AM #20 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
9:09:53 AM #21 Text 0 File CUDFTransferItem2.cpp, Line 672
GenUDF2 FS Layout:
Sectors to be written: 11700800
Session Start: Sector 0
Volume Structure: Sector [0, 256] (257 Sectors)
Meta Data: Sector [257, 365] (109 Sectors)
Data: Sector [366, 11700476] (11700111 Sectors)
After Data: Sector [11700477, 11700479] (3 Sectors)
Trailer Track: Sector [11700480, 11700799] (320 Sectors)
GenUDF2 Parameters:
PrepTime: 05-15-2008 09:09:20
UDF Revision: 1.02
UDF Partition Type: Physical
UDF Special Mode: None
Bytes per Sector: 2048
Session Start: 0
Physical Partition Start: -1
Total Capacity: 11826176
Multi Session Mode: None
Disc Type: BD-R
OS Class: 0
Volume ID: Porn HD
Allow Unicode Labels: 0
Duplicate Meta Data: 1
MS Info File: 00000000
VMS Rollback File: 00000000
Create ISO bridge: 0
ECC Block Length: 32
Sparing Packet Length: 32
Allocation Unit Size: 32
Alignment Unit Size: 32
Make Writable: 0
Access Type: Read-only
9:58:32 AM #22 SPTI -1114 File SCSIPassThrough.cpp, Line 196
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1114)
CDB Data: 0x5C 00 00 00 00 00 00 00 0C 00 00 00
Sense Key: 0x06 (KEY_UNIT_ATTENTION)
Sense Code: 0x29
Sense Qual: 0x00
Sense Area: 0x70 00 06 00 00 00 00 0A 00 00 00 B4 29
Buffer x083fc480: Len xc
9:58:32 AM #23 SPTI -1064 File SCSIPassThrough.cpp, Line 196
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1064)
CDB Data: 0x2A 00 00 5E 35 A0 00 00 20 00 00 00
Sense Code: 0x21
Sense Qual: 0x02
Sense Area: 0x70 00 05 00 00 00 00 0A 2A 00 00 B4 21 02
Buffer x0e193680: Len x10000
0xF6 AB 24 06 37 D7 37 6F EF 72 3B D3 97 68 BA 73
0x14 A9 55 45 56 7E B1 88 72 94 AA F6 B1 4C D3 BF
0x09 C7 6E B2 25 8C AB BF 63 3B F6 87 29 1D 81 DE
9:58:32 AM #24 CDR -1064 File Writer.cpp, Line 306
Invalid block address
9:58:43 AM #25 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 6x (26,970 KB/s)
9:58:43 AM #26 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
9:58:48 AM #27 Text 0 File Cdrdrv.cpp, Line 11420
DriveLocker: UnLockVolume completed
9:58:48 AM #28 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
eternalkp is online now Report Post Edit/Delete Message
eternalkp
Postby hoxlund on Thu May 15, 2008 11:25 am
make sure you have a fresh restart in there, i can't stand nero 8 but if thats what you have to use
can you try nero 7? the latest build?
what are you burning? a movie backup or what? if so what did you use to back it up?
Postby hoxlund on Thu May 15, 2008 11:29 am
3gb of ram? how is that installed? like how many sticks and how big is each stick?
latest motherboard bios?
for me $12 a pop for burning coasters is VERY unacceptable, i would run my machine through every hardware test
memory, HD, stress test, just a full list of tests
memory - memtest 86+
HD - Drive Fitness Test
Stress Test - prime 95 on all cores while looping 3dmark 06
disconnect the other optical drive while burning bluray perhaps just eliminate all possibilities
Postby Ian on Thu May 15, 2008 12:28 pm
Normally I'd tell you to update your firmware and/or software but it looks like you're up to date on both.
I haven't burned any Blu-ray discs with Nero 8 but with Nero 7 there was a feature/bug where the software would auto-verify everything it wrote to disc. It made the burn process take twice as long.
Also, do you have the drive connected to the Silicon Image RAID controller?
Postby dolphinius_rex on Thu May 15, 2008 5:02 pm
All of the above suggestions are good... but for goodness sake man, start off by buying a BD-RE (re-writable) disc!! This is a new technology you're working with, and it's expensive. Make your mistakes on a disc that won't coaster on you. Once you've got it down pat, THEN bring on the BD-Rs.
Postby hoxlund on Thu May 15, 2008 9:33 pm
well theres only 3 hard drives and 2 optical drives so im sure hes all onboard sata no addin cards
Postby Ian on Thu May 15, 2008 11:12 pm
hoxlund wrote:well theres only 3 hard drives and 2 optical drives so im sure hes all onboard sata no addin cards
Yeah, they're all onboard but four of them use the nvidia southbridge. The rest are for the raid controller.
Postby eternalkp on Fri May 16, 2008 5:00 pm
yes, all 4 SATA are filled up
3 harddrives
1 bluray burner
i am not sure what's going on but i am testing with NERO DISC SPEED 4 with THE DEPARTED bluray and all the drive does is 1X. i am so mad. it's supposed to read @ 6x.
eternalkp
Postby Ian on Fri May 16, 2008 10:37 pm
Well, it reads AACS protected discs at 4x.. but that's still a lot faster than what youre' seeing.
I'm not really sure what the issue is. I have a similar AMD system and haven't had any problems with SATA optical drives. Do you have another computer you can try it in to make sure its not a lemon?
speedless
Postby eternalkp on Sat May 17, 2008 5:54 pm
i am not sure what's wrong with the drive.
i try to Nero SpeedDisk4 with a bluray movie, 300.
the drive never goes beyond 3x...where is my official 6x read?
6x bluray burn takes an hour.
eternalkp
Re: speedless
Postby Ian on Sat May 17, 2008 8:02 pm
eternalkp wrote:i am not sure what's wrong with the drive.
Can you post a screenshot of it reading 300?
Postby Bhairav on Tue May 20, 2008 6:44 am
@Ian - those older 939 systems have issues with SATA opticals. My DFI definitely does.. still haven't got my 212 working with it.
He should try using a PCI add-in SATA controller..
Postby Ian on Tue May 20, 2008 7:54 am
Bhairav wrote:@Ian - those older 939 systems have issues with SATA opticals. My DFI definitely does.. still haven't got my 212 working with it.
Hmm.. its an nForce 4 motherboard. I didn't think that those still had problems.
