LG GCE 8400B -- speed issues
Postby vqkin on Fri Jan 10, 2003 4:54 pm
Damned Windows Restore!!!!
vqkin
Postby vqkin on Fri Jan 10, 2003 4:55 pm
I must say that i did actually even format both computers where said problem presented itself an it still wouldnt work
vqkin
Postby dodecahedron on Sat Jan 11, 2003 12:41 am
vqkin wrote:Got a Good one for you. I bought the LG GCE-4800b and used it great for about a month on my home computer. After that time, it suddenly started recording slower than usual, going from 40x to 8x approximately. I didnt change the media or did nething weird on my computer. Thinking it was a defective drive, I bought a Plextor 48/24/48 and decided to take this one in for check up. I brought it into the office and one of mycoworkers suggested I try it on one of the computers at work. I did so not only in one but on 3 computers, using same programs and different ones to be sure. In every single one, it burned at the expected speed of 40x or 30+. Believing it now to be a problem with my home computer, I installed the drive on my work pc and started using it for some time. It was working great. Using any sort of media I burned at around 30-40x, nething under 3:00 mins. I was greatly satisfied and just about to regret having bought the Plextor. Just 2 days ago, about one month since I installed it on my computer, the damned thing started presenting the exact same problem of recording slowly. Using the same media that I used to burn about 60 CDs. (Benq by the way 48X certified since i got the Plextor). All of a sudden, nothing having changed, not even rebooting the computer or anything I'm back to 8-12x recording. Any ideas, comments ?
sounds like DMA.
make sure DMA is activated.
read the previous posts in this thread.
