GCE-8400B Overburn problem
Postby ts_999 on Thu Jun 26, 2003 12:07 pm
I have a LG gce-8400b OEM version from dell, it refuses to overburn, although nero said it support overburn. I follow the instruction in setting the preference so that it will do disc at once overburn, but it stopped immidately before the real burn process and asked for a larger cdr. I even trick Wincdr by build a 703M iso, Wincdr burn it until 99%(702M?) and stopped with a error. Is the OEM version of GCE-8400b different from the retail version, can it do overburn. My system is P4 with xp.
ts_999
Postby Ken on Thu Jun 26, 2003 1:06 pm
Make sure you are not using the wizard in Nero or it won't work.
Ken
Postby HBK4550 on Thu Jun 26, 2003 7:56 pm
Upgrade to the latest bios.
Are You Ready To Play The Game?
HBK4550
Postby blakerwry on Fri Jun 27, 2003 7:50 pm
you've enabled overburning in the nero preferences, right?
blakerwry
