Hi guys, I hope I am in the right forum to ask this question. I bought the LG combo drive listed in the topic and I have a little issue with it. When I try burning something using the latest Nero software my computer becomes severly lagged, for example: my mouse becomes very choppy and multi-tasking is almost impossible because it takes a good 10-15 seconds or so for things to pop up or open. Is this normal? I've tried various versions of Nero (older and the latest) and Cdrwin3 and Cdrwin5, all the time it does the same thing.
I'm using a Windows 2000 OS (SP3) on a Athlon XP1700+ CPU with 256meg DDR ram and a Asus Nforce420 motherboard.
I have it currently set to slave on IDE2 cable, which it shares with a HD.
My bios see's the drive as a ultra dma33 or 2 and my HD is ultra-100 compatible, but since im using a dma66 cable, my HD and combo drive are both runing at dma33.
Does anyone see any problems here? Is this how it's supposed to run?
I would greatly appreciate any help on this subject
![:)](http://cdrlabs.com/forums/images/smilies/icon_smile.gif)
thanks!
