HI,
I have a Verbatim DVD+RW which is an OEM NEC 1000 unit.
Purchased at Frys on 23rd March this year.
Today it permanently flashes the Green Activity light, and when I check the properties it appears to have the wrong product description, i.e an NEC 1100.
I don't recall trying to flash it with different firmware. Although I did try the NEC 1000 firmware from firmware-flash.com
Its not immediately possible to return it to Frys as the drive is in the UK with me.
Is there anyway of re-flashing it, and tools to use.
Verbatim Support said send it back, but that will take a while to resolve, I'd rather try and troubleshoot a bit further.
I hope someone can help me.
Mark
