Firmware upgrade for Lite-On LTN526D?
How fast is too fast?
Postby SkaarjMaster on Sat Apr 10, 2004 6:37 pm
My Mom has this 52X CD-ROM and right now the firmware is YSR5 under Win98SE. I noticed firmware at Lite-On for the LTN526S as YSON. Is this the one I need for a firmware upgrade or should I not even bother?
SkaarjMaster
Postby TheWizard on Sat Apr 10, 2004 7:49 pm
My advice, if it ain't broke, don't fix it. However, if you want to peruse other firmwares for your drive, visit http://www.firmware-flash.com.
No, I like women.
Postby SkaarjMaster on Sat Apr 10, 2004 9:17 pm
I don't seem to be able to get to that site right now with my Mom's computer. I was also wondering if the YS0N is the right firmware for the LTN526D because the Lite-On site says LTN526S?
SkaarjMaster
Postby TheWizard on Sun Apr 11, 2004 11:46 pm
The site is working; it may have been down when you previously tried.
Good question about the model number and firmware version; in situations like this, I take a look at the current firmware of the drive. For example, if your LTN526D has a current firmware of YH0K, YS0E, YS0F, YS0G, OU0J, or YS0J, then you know that falls under the LTN526S, therefore the next progression would be YS0N. If the drive has a current firmware of YH0X then you know that falls under the LTN526. I realize this is a crude way to figure out which drive you have, but it usually works. Note, I said usually. As I mentioned before, if there are no visible problems with the drive, then don't upgrade the firmware. No action, in this case, is the safest action.
No, I like women.
Postby SkaarjMaster on Thu Apr 15, 2004 3:23 pm
Unless I find a definite answer, I'll leave it like it is for now. I got to that site at work today and it looks like the 526S firmware would work but still not sure. I'm DLing them anyway just in case I decide to do it. Anyone know for sure what's going on here?
This interesting little tid bit says this drive doesn't support flashing, so I guess that's the answer I was looking for. No wonder the drives were so cheap when I bought it for her, hehe. No big deal though, no problems yet.
http://www.liteonamericas.com/us/CDROM_ltn526d.htm
SkaarjMaster
Postby SkaarjMaster on Tue May 04, 2004 3:06 pm
I finished installing her system and didn't flash the drive as it may not support it. Everything's fine for now. This drive sounds like an airplane taking off though, hehe. 8)
SkaarjMaster
