FIRMWARE FLASH FAILURE
How fast is too fast?
Postby davros on Sun Dec 11, 2005 5:15 pm
Hello forum. Today I tried to update the firmware on my ASUS DVD-616A dvd drive and the windows flash tool simply locked up my pc causing me to reboot after waiting 15 mins or so. Now windows wont boot at all with this drive attached. I opened the dvd's case and noticed the main chip inside has MT1355PE wrote on it.......does this mean its a mediatek chip that can be recovered in DOS using mtkflash??? If it indeed is...then I have another problem ...I dont have a BIN. firmware for this drive (I have looked on the net everywhere)..Can anyone help please???/ I need a bin firmware and instructions on how to flash (jumper arrangement etc.) THANKS IN ADVANCE CHAPS!!!!!!
davros
Postby dodecahedron on Mon Dec 12, 2005 2:49 am
hello (again) davros, my fellow Whovian.
did you check out www.rpc1.org ?
I have tried everywhere!!!
Postby davros on Mon Dec 12, 2005 11:36 am
Hello again dodecahedron mate !! I have found quite a few sites with the windows exe. flash tool firmware but I need the BIN file to use mtkflash to revive the drive. does anyone have an asus 616a that would kindly send me a bin file of the firmware????.......................regards davros
davros
