file too big and no sound with tmpgenc
Video editing, capturing, converting, etc.
Postby kouyate on Wed Oct 06, 2004 9:55 am
hello there, complete newbie here!! I just followed one of your tutorials on how to convert an avi file using tmpgenc, firstly it took 11 hours to convert (is this normal), i also got a warning telling me the file was too big for a normal dvdr, but when it had finished converting, i checked it there is no sound, and altho the original film is only 1 hr 30 mins long, the converted file runs for over 5 hours long, so after the film ends there is just a black screen that carries on running for another 3 hours or so!!!!
What did i do wrong, and if you can help please be gentle with me and explain it slowly cause i dont know what im doing !!!!!
Many thanks
kouyate
Postby Scour on Wed Oct 06, 2004 12:08 pm
I thinks, it´s the wrong forum, but here some tipps:
1. TMPG have problems with the audio, so use Nandub or Virtuadub, open the avi and save the sound as wav-File. Then load teh avi in TMPG and select the wav-file as audio.
2. Use DVD2SVCD(Freeware) with the TMPG-Encoder, it works better than only TMPG
Postby Bhairav on Wed Oct 06, 2004 12:49 pm
Please don't double post. Stick to the thread in DVD Authoring.
Return to Video Editing
