EAC drive offset confusion
How fast is too fast?
Postby audiodrome on Mon Jan 16, 2006 8:09 pm
Can someone make sense of this for me. I got the correct read offset for my burner (+6) from accuraterip.com, but I don't know where to enter it. Some "manual" say put it in the read offset box, but others say that if you use another program othan EAC to write then you should use combined read/write offset. So do I put the +6 in that box? Still another said that I need to switch back and forth depending on if I rip audio from a factory CD or a CDR.
Paul
audiodrome
