CowboySlim wrote:Can you try it with Windows XP or Kubuntu?
Why do you not think that it might be a Vista issue?
Kubuntu is a Linux distro.jayrodathome wrote:what is kubuntu
margrave wrote:I had a similar problem with my 212 in Vista until I set the dvd region for the drive in device manager. Autoplay didn't work, Nero couldn't detect a disc in the drive, etc. Since I set the region it works fine.
Try that before you return the drive as defective...
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 1 guest
