CD-DVD Speed 4.01 (Nero Speed) Limit the burning Speed?
Postby ziggy on Sat Jul 09, 2005 1:15 pm
So this little peace of software can now burn DVD Image files which is pretty good. Is there a way to limit what the burnning speed is? I found an option but all it does is change the graph scale. Can maybe Nero Burner show what speeds it used throughout the whole burn?
ziggy
Postby dodecahedron on Sat Jul 09, 2005 1:30 pm
what option is that?
do you mean in Options | Standard Tests | Transfer Rate | Maximum speed DVD ?
i think what you need is Options | Standard Tests | Speed | Write speed, choose Selected instead of Maximum
