DVD shrink 3.2 Quality settings?
Postby Chip on Wed Aug 25, 2004 4:17 pm
I just installed 3.2 last night and when I back one of my movies up to my hard drive the Quality settings are grayed out and I can't check them.
Anyone know why this is?
Chip
Postby burninfool on Wed Aug 25, 2004 5:56 pm
If you don't compress they will be grayed out.
Postby Chip on Wed Aug 25, 2004 6:03 pm
I do compress the dvd but then when I select backup, and quality settings I can't select anything.
Is this because I am backing it up to the harddrive?
Shouldn't be ...
Chip
Postby hoxlund on Wed Aug 25, 2004 6:03 pm
did you click the checkbox "Compress video with high quality adaptive error compensation:"?
Postby Chip on Wed Aug 25, 2004 6:11 pm
I can't select either items...
Chip
Postby hoxlund on Wed Aug 25, 2004 6:13 pm
and your sure your project is big enough to use compression?
like as in you have some red space in the projected size?
Postby Chip on Thu Aug 26, 2004 8:28 am
So I guess I thought one could apply it to any backup. But if I understand you correctly the items can only be checked if you are over compression(in the red area)...which leads to these items can't be checked on any backup that is in the Green area. Is this correct?
Chip
Postby hoxlund on Thu Aug 26, 2004 10:34 am
just so we understand, which quality settings are we talking about?
where are they exactly in dvdshrink
Postby hoxlund on Thu Aug 26, 2004 10:38 am
ok i think i figured out what your trying to say
those options will be grayed out if your compression settings are set to 100% meaning that you want full quality and don't want to compress at all
so if you drag the custom ratio sliding bar all the way right, meaning 100% quality - no compression you won't be able to use the quality settings in the backup dialogue box
Postby Chip on Thu Aug 26, 2004 11:44 am
Got it.....will verify tonight but I think it all makes sense now.............
Thanks for the info.
Chip
