DVD Shrink Problem?
DVD Shrink Problem?
Postby smartin4 on Mon Jan 17, 2005 8:28 pm
I have recently begun using Shrink (v 3.2.0.15) more often than in the past. I have backed up between 12-15 discs over the last 2 weeks. The problem is that the backup copies seem to hang and skip a few frames at 3 or 4 different spots during playback. This has happened with 3 different movies so far (I haven't had time to view them all).
I know it is not my standalone player, as I lent my Chappelle backup to a friend and she had the same problem on a completely different brand of standalone player.
Any thoughts on what might be causing the issue?
My computer is: 1.8 GB P4, 1GB RAM, backing movies up to 80 GB Maxtor 7200RPM. Using a Lite-On LDW-851S to read & to do the burn. FW is GSC2.
smartin4
Postby rdgrimes on Mon Jan 17, 2005 8:42 pm
How much compression have you used on the problem discs?. Are they a new kind of media? Different burn speed? New drive firmware?
Often, playback problems are a result of an underlying player incompatability with the media, and very small differences in the burn quality can cause freezes and picture breakup. Over-compression of the video can also cause troubles, but using the new "quality settings" in Shrink will overcome most of these problems.
rdgrimes
Postby Noua on Tue Jan 18, 2005 5:28 am
I would recommend that you use bether media. Also do a quality check test on the nurned dvds to check the error rates.
"We don't want to to put mankind on the moon but to bring mankind back to earth..."
Noua
Postby hoxlund on Tue Jan 18, 2005 1:18 pm
make sure your 80gb stays defragged if you put movies on them then burn off it
i would think if you have a movie stored on a hard drive then defrag it, it might interrupt the continuity of the image
just my theory
Postby ETP on Tue Jan 18, 2005 6:40 pm
I always use TY+R and shrink the movie down to the bare min. Delete credits and intro as well as all additional languages and sound other than 5.1. Stay away from the 2 channel. Some of that is director comments that are unlabeled.
No problems yet! Burning at 16x with a 3500.
BQ 1640 BSOB
NEC 4550 1.6T
Plextor 716a 1.09
Pioneer 109/A09 158
Pioneer 110/A10 1.39
Liteon 5005
Sony 875P & 333ES
Liteon 5005
HK7200
Hitachi 61SDX
ETP
Postby hoxlund on Wed Jan 19, 2005 1:07 am
yeah before i include any 2 channel sound i preview it in dvdshrink to see if its the commentary
Postby ETP on Sun Jan 23, 2005 8:31 am
Like this would never happen. #-o When I first used Shrink I selected 2 channel as suggested in the Shrink guide and burned my first 3 disks with director comments that were labeled 2 channel stereo. #-o
Since I leave my speakers off I did not know what was happening. It's time to turn those speakers on eh! #-o
PS/ The Forgotton was the first movie I was forced to use decrypt 3.2 first.
BQ 1640 BSOB
NEC 4550 1.6T
Plextor 716a 1.09
Pioneer 109/A09 158
Liteon 5005
Sony 875P & 333ES
Liteon 5005
HK7200
Hitachi 61SDX
ETP
