DVD Rebuilder + CCE settings
Postby ModDoc on Sun Aug 29, 2004 1:22 pm
Hi all, I am new to the DVD ripping scene, and from what I found, DVD Decrypter, and Rebuilder + CCE seems to be the best way to backup movies.
I am curious, at to what settings you guys like to use for Recuilder/CCE. (and what version of CCE, since it seems to work differently from 2.5 to 2.66).
VBR_Bias, Quality_Prec, and VBR_Passes, along with any other significant ones.
Thanks in Advance.
ModDoc
Postby ModDoc on Sun Aug 29, 2004 7:53 pm
Well... no replies yet, but here is what I've been using for my CCE 2.5
VBR_Bias = 25
Quality_Prec = 16
VBR_Passes = 3
Steal Space from Extras = 33%
So far, so good, and it seems to size them all nicely to fit on one DVD.
ModDoc
