DVD (JLMS XJ-HD166S) problems
How fast is too fast?
Postby Felix on Thu Mar 27, 2003 8:26 am
Error msg:
WinDVD MFC Application has had an error etc.
AppName: windvd.exe
AppVer: 4.0.5.43
ModName: gpiproxy.dll
ModVer: 4.0.5.43
Offset: 0013e775
Whenever i try to play a DVD with WINDVD i get that error msg....
can someone plz try to help me figure it out?
my DVD drive is JLMS XJ-HD166S and iam running Win XP Pro
Felix
Postby cfitz on Thu Mar 27, 2003 2:06 pm
That sounds like an issue with your WinDVD installation, not with your drive. I would suggest contacting InterVideo:
http://www.intervideo.com/jsp/Faq.jsp?mode=Support
Postby Han on Thu Mar 27, 2003 2:09 pm
First, make sure you've set the region for your drive. If you've set it as region free, you have to run RegionKiller or DVD Genie application to simulate the region.
Then try the latest WinDVD or WinDVD Platinum (4.5.11.26).
Han
CD-RW PiMP
Postby cfitz on Thu Mar 27, 2003 2:10 pm
You might also want to try different video card settings and update your video card drivers.
Postby Felix on Fri Mar 28, 2003 5:53 am
thx guys, it was my Win DVD version.... all fixed now :)
Felix
Postby cfitz on Fri Mar 28, 2003 10:53 am
Glad to hear it. And thanks for reporting back what fixed your problem. It might help someone else down the road.
Postby Felix on Sat Mar 29, 2003 7:24 am
hey thats the least you can do :)
Felix
Postby Implicit on Wed Apr 02, 2003 12:18 pm
Is there anything special you have to do to get this unit to work with DXC?
Just installed one yesterday and it doesn't seem to want to backup DVDs. Do I need a special firmware for the region or something?
Implicit
Postby Implicit on Wed Apr 02, 2003 12:19 pm
Implicit
JLMS XJ-HD166S DS0F only reads CDs
Postby techsupp101 on Tue Apr 29, 2003 11:31 pm
Help!
My DVD drive is working fine a few weeks ago but now it is unable o read DVDs. I'm not sure if the drive itself is busted but it can still read CDs.
I did not make any major changes on my PC. I can't figure out what went wrong. When a DVD is inserted into the drive, windows explorer displays undefined on the drive letter. I even upgraded it to firmware DS0F but that did not fix the problem instead it only restored the regional protection code.
techsupp101
