eric93se wrote:Does anyone know if the driver selected (spti, aspi, elby...etc..) has any impact on the write quality, or is it soly for ripping purposes.
No it doesn't,it's how your device communicates with the OS.Win9x/Me uses WINASPI32.dll,2000/XP uses SPTI.I wouldn't mess with it.
@dodec,
This is how I set up DVDDecrypter:
Remove all PUOs.
Untick all file associations(.img,.nrg,etc).
Disable Auto Insert Notification.
Set Buffer Size to ~75MB.
Tick Ignore Read Errors and set read/write retries to 0.
Untick Create MDS file(if you use FAT32 then leave ticked).
Set Transfer Length to 32KB.
Some recent DVD's have ARCCOS protection that DVDDecrypter can't handle so use DVDFab Decrypter(free) instead.
