DVD copying help
DVD copying help
Postby winson2001 on Fri Dec 26, 2003 4:47 am
I'm new to DVD-R and uses Nero Express with Pioneer DVR A06U
When I try to backup my LOTRTT(DVD moive) it said not enough space with my DVD disk. what is wrong? or what software should I use? please help!
Thank You!
我係呀仔
$10,000/year Insurence for a $500 beater!
winson2001
Postby Han on Fri Dec 26, 2003 5:44 am
You need Recode 2 which is a part of NeroVision Express... There are many programs to backup DVD movies. Just search the forum or use a search engine like Google.
Han
CD-RW PiMP
Postby NoSmartz on Fri Dec 26, 2003 12:05 pm
Try DVDShrink 3 then use Nero for Burnin'. http://www.dvdshrink.info/
Or if you like Nero recode 2,you have to use an app called "DVD Region Free" or "AnyDVD" to rip to your HD for Recode 2 to work like it's suppose to. http://www.doom9.org/index.html?/mpg/ra-guide.htm
E
Soren Kierkegaard
NoSmartz
Postby BurninMan921 on Fri Dec 26, 2003 12:56 pm
You can use DVD Decrypter (which is free!) to copy the DVD to the hard drive, then use Nero Recode 2 to compress it.
Recode2 is basically the next version of DVD-Shrink; it has better quality than 3.05b, and was written by the same person. But you have to use a seperate program to decrypt the DVD. DVDShrink is an "all-in-one" type of program.
BurninMan921
Postby winson2001 on Sat Dec 27, 2003 3:16 am
Thank You guys! I've talked to a few people about this issue, and have tried using DVDshrink, but most people say they don't need to compress over 25%. when I tried, I have to compress it to 40%(level8) to fit in my DVD disk! did I have any setup wrong?
我係呀仔
winson2001
Postby Turkeyscore.com on Sat Dec 27, 2003 4:57 am
I got DVDXCopy Express for free from compusa after buying Microsoft Office 2003, not sure it it is any good because I dont have a DVD burner but oh well :)
i might get one eventually though
zzzt *pop*
Turkeyscore.com
Postby Han on Sat Dec 27, 2003 6:42 am
winson2001 wrote:Thank You guys! I've talked to a few people about this issue, and have tried using DVDshrink, but most people say they don't need to compress over 25%. when I tried, I have to compress it to 40%(level8) to fit in my DVD disk! did I have any setup wrong?
It all depends of a movie, its length, screen format, etc. To fit a three hour movie to a single DVD the program must compress it to around 50%.
Btw, CloneDVD seems to me as the easiest "cloning" solution. You just throw in a movie, select video and audio parts, and wait until the ripping and writing process is finished...
Han
CD-RW PiMP
Postby winson2001 on Sun Dec 28, 2003 2:46 pm
but i was just trying to fit disk 1 of 3 of LOTR into 1 disk, I do plan to use 3 disks for the whole movie! is it normal to be compressing at this level?
我係呀仔
winson2001
Postby Han on Sun Dec 28, 2003 3:40 pm
Yes, it's normal, because a recordable DVD disc has only one layer and can thus hold 'only' 4.38 GB. Pressed LOTR DVD has two layers and holds over 7 GB of data...
Han
CD-RW PiMP
Postby winson2001 on Sun Dec 28, 2003 6:29 pm
Thank you! ^_________^ :P
我係呀仔
winson2001
Postby NoSmartz on Sun Dec 28, 2003 8:01 pm
Stay away from it turkeyscore.com.I tried it before DVD Shrink and the first 2 discs I put in hung and froze everything on my pc.Luckily I used DVD+RW's so no waste there.There's much better stuff out there like DVD Shrink,Recode 2(nero),DCS Dvd Copy Suite and many others.None of these other apps puts a watermark on the burnt disc so you can't copy it again.I think it's great that company(321 studios) pushes for freedom to copy anything you purchase but their product is average.
E
Soren Kierkegaard
NoSmartz
Postby govern1 on Mon Dec 29, 2003 11:39 am
I completely disagree that 321 Studios product is average. I just bought DVD XCopy Gold this weekend and it has worked flawlessly for me! I've backed up 10 movies so far and not one coaster or problem.
govern1
