dvd burning is taking around 40 minutes please help
Postby bozza43 on Fri Dec 07, 2007 3:56 pm
hiya im having problems burning dvds and data dvds they are taking ages around 40 minutes for both i never used to have this problem ive joined this site to see if ayone can help ive got it in dma mode im new to this so i dont really no what to do this is the log off nero please can someone let me know what the problem might be thanks in advance
bozza
1K22-0867-0795-66M4-5759-1017-****
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.1.1.3
Internal Version: 8, 1, 1, 3
(Nero Express)
Recorder: <LITE-ON DVDRW SHW-1635S> Version: Y9C4 - HA 1 TA 1 - 8.1.1.3
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: <HL-DT-ST DVDRAM GSA-H10A >Version: JL05 - HA 1 TA 0 - 8.1.1.3
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SP4002H atapi Port 0 ID 0 DMA: Off
CdRomPeripheral : HL-DT-ST DVDRAM GSA-H10A atapi Port 1 ID 0 DMA: On
CdRomPeripheral : LITE-ON DVDRW SHW-1635S atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-H10A E: CdRom0
LITE-ON DVDRW SHW-1635S D: CdRom1
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Physical memory : 1535MB (1572080kB)
Free physical memory: 1205MB (1233992kB)
Memory in use : 21 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
7.12.2007
ISO compilation
01:49:21 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
01:49:21 #2 Text 0 File Isodoc.cpp, Line 6671
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
01:49:22 #3 ISO9660GEN -11 File Geniso.cpp, Line 3347
01:49:22 #4 Text 0 File Burncd.cpp, Line 3530
01:49:22 #5 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator 'CUDFSettingsValidatorDVD'
ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
Changing UDF revision from '1.02' to '1.02'
01:49:22 #6 Text 0 File FilesystemSettingsValidator.cpp, Line 142
01:49:43 #7 Text 0 File FilesystemSettingsValidator.cpp, Line 142
01:49:45 #8 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1631055 (362:27.30, 3185MB)
01:49:45 #9 Text 0 File DlgWaitCD.cpp, Line 319
01:49:45 #10 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: LITE-ON DVDRW SHW-1635S, Media type: DVD-R
Disc Manufacturer ID: <CMC MA> <G. AM3>
01:49:45 #11 Text 0 File DlgWaitCD.cpp, Line 493
Disc not writeable. Insert writeable disc.
(Medium in drive: DVD-R. Medium required by compilation: DVD R/RW, DVD DL.)
01:49:45 #12 Text 0 File ThreadedTransferInterface.cpp, Line 785
0: TRM_DATA_MODE1 ()
original disc pos #0 + 1631056 (1631056) = #1631056/362:27.31
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1631056 blocks [D: LITE-ON DVDRW SHW-1635S]
01:49:45 #13 Text 0 File ThreadedTransferInterface.cpp, Line 986
Prepare [D: LITE-ON DVDRW SHW-1635S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3340402688, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 1631056 | 0 | 0x00
1631056 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
01:49:45 #14 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
01:49:45 #15 Text 0 File Burncd.cpp, Line 4316
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
01:49:45 #16 Phase 24 File dlgbrnst.cpp, Line 1764
Caching of files started
01:49:45 #17 Text 0 File Burncd.cpp, Line 4435
Cache writing successful.
01:49:45 #18 Phase 25 File dlgbrnst.cpp, Line 1764
Caching of files completed
01:49:46 #19 Phase 36 File dlgbrnst.cpp, Line 1764
Burn process started at 16x (22,160 KB/s)
01:49:46 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2735
01:49:46 #21 Text 0 File DVDR.cpp, Line 3245
Recording mode: Sequential Recording Mode
01:49:46 #22 Text 0 File DVDR.cpp, Line 3401
Start write address at LBA 0
01:49:46 #23 Text 0 File Cdrdrv.cpp, Line 10026
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Outer Limit of Data Recordable Area: 26127F h
Revision number of maximum recording speed: 6.0
Revision number of minimum recording speed: -
Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
Class: 0, Extended part version: 33
Start PSN of the Extra Border Zone: 0 h
Start PSN of Physical format information blocks in Extra Border Zone: 0 h
Media Specific [16..783]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
01 40 C1 FD 9E D8 52 00 - 02 84 0D 12 98 99 90 00 .@....R.........
03 43 4D 43 20 4D 41 00 - 04 47 2E 20 41 4D 33 00 .CMC.MA..G..AM3.
05 88 80 00 00 00 02 00 - 06 09 0D 14 98 88 90 00 ................
07 88 80 00 00 00 00 00 - 08 07 17 0A 0E 09 04 00 ................
09 95 07 0D 0B 88 88 00 - 0A 80 00 00 00 00 10 00 ................
0B 06 17 15 B8 99 85 00 - 0C B8 9A 32 03 20 32 00 ...........2..2.
0D 00 00 D0 00 00 00 00 - 0E 09 1F 39 2F 25 1C 00 ...........9/%..
0F 50 19 29 19 89 B5 00 - 10 88 84 00 04 00 04 00 .P.)............
11 00 00 00 00 00 00 00 - 12 09 2B 37 2D 29 1B 00 ..........+7-)..
13 50 1D 2D 1F A6 B5 00 - 14 88 80 00 00 00 00 00 .P.-............
15 00 00 00 00 00 00 00 - 16 0B 45 3D 3B 1F 25 00 ..........E=;.%.
17 30 25 31 0D 8A B5 00 - 18 88 80 00 00 00 00 00 .0%1............
19 00 00 00 00 00 00 00 - 1A 0C 51 51 51 45 2D 00 ..........QQQE-.
1B 90 23 2D 19 79 B5 00 - 1C 88 80 00 00 00 00 00 ..#-.y..........
01:49:46 #24 Text 0 File ThreadedTransfer.cpp, Line 268
Pipe memory size 83836800
01:50:52 #25 Text 0 File Cdrdrv.cpp, Line 1367
01:50:52.046 - 㩄䰠呉ⵅ乏䐠䑖坒匠坈ㄭ㌶匵  : Queue again later
02:18:40 #26 Text 0 File WriterStatus.cpp, Line 113
<D: LITE-ON DVDRW SHW-1635S> start writing Lead-Out at LBA 1631056 (18E350h), length 0 blocks
02:19:00 #27 Text 0 File DVDR.cpp, Line 3803
EndDAO: Last written address was 1631055 (18E34Fh)
02:19:00 #28 Phase 37 File dlgbrnst.cpp, Line 1764
Burn process completed successfully at 16x (22,160 KB/s)
02:19:00 #29 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
02:19:06 #30 Text 0 File Cdrdrv.cpp, Line 11276
DriveLocker: UnLockVolume completed
02:19:06 #31 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
bozza43
Postby Ian on Fri Dec 07, 2007 4:04 pm
Are you trying to copy from one drive to the other?
Postby bozza43 on Fri Dec 07, 2007 4:14 pm
hiya im trying to copy from my hard drive and from one drive to the other its a bit quicker if im copying it from one drive to the other but not very much quicker
bozza43
Postby ala42 on Fri Dec 07, 2007 10:29 pm
Enable DMA for your harddisk. You find instructions in the FAQ thread.
As you already noticed, copying data from a source to a target drive connected to the same IDE bus is a very bad idea.
ala42
Postby bozza43 on Sat Dec 08, 2007 3:05 pm
hiya im a newbie to this but i know that the hard drive and dvd drives are on different ide cables is that what you mean sorry if i sound thick lol
bozza43
Postby ala42 on Sat Dec 08, 2007 3:22 pm
Which part of "Enable DMA for your harddisk" is so hard to understand :)
ala42
Postby bozza43 on Sat Dec 08, 2007 3:41 pm
i thought this site would be great but its just full of smart asses id rather my computer go slow than get help from you people wont be using this site again you forget you had to learn this stuff once
bozza43
Postby Ian on Sat Dec 08, 2007 8:11 pm
bozza43 wrote:i thought this site would be great but its just full of smart asses id rather my computer go slow than get help from you people wont be using this site again you forget you had to learn this stuff once
bozza43, ala provided a link full of FAQ's. Maybe a direct link would be better?
http://www.cdrlabs.com/forum/viewtopic.php?t=7625
