DVD Burning Help
DVD Burning Help
Postby freemchr on Sun Feb 23, 2003 7:24 pm
Hi Im trying to burn an .iso to a DVD using Nero. Whenever I go to select the ISO and attempt to burn it it comes up with the error message that the compilation will not fit onto the CD. The iso is only 40mb.
Your help is appreciated.
freemchr
Postby IndieSnob on Sun Feb 23, 2003 7:55 pm
Your problem is that when you go into Nero and open the iso to burn the drag-down menu is on cd, which means your trying to burn the iso to cd, not dvd. Just click on the drag-down menu and select 'dvd' and you're good to go.
IndieSnob
