MY DVD/CD BURNER PLAYS BUT WILL NOT BURN ... PLEASE HELP
Postby zeppe on Fri Mar 14, 2008 7:26 pm
HI
I USE NERO 8 ... & EVERY TIME I TRY TO BURN MP3 OR AVI,
IT STARTS TO BURN BUT STOPS & SAYS BURN PROCESS FAILED..
POWER CALIBRATION... OR PLEASE YOU DIFFERENT MEDIA ...!!!
IT NEVER DID THIS BEFORE...!!!!
I HAVE A MASHITA DVD BURNER MODEL UJ - 482D
AS FOR THE MEDIA I HAVE USED DVD + R/RW & DVD - R/RW
EVEN DUAL LAYER OF BOTH FORMATS...
YET I STILL GET THIS ERROR ...... PLEASE YOU DIFFERENT MEDIA !!!
WHAT DO I DO TO FIX THIS.....????
zeppe
Postby Ian on Fri Mar 14, 2008 9:10 pm
Normally I'd tell you to use other media but you've already done that.
Have you installed some other burning software recently that may be causing problems with Nero? Have you tried software other than Nero?
Postby 2Dogs on Fri Mar 14, 2008 10:03 pm
You might try running the Nero Info Tool, part of the Nero toolkit, to check the capabilities of your burner. Many laptop burners are not dual format.
Might also be worth trying to re-load the firmware.
KHypermedia 8x4x12 (BenQ 800 clone) B2L7 BenQ DW1655 BCIB BenQ DW1650 BCIC Samsung SH-S182M KC03 LG GSA-H22N 1:01 TDB Lite-On SHM-165H6S HS0E Pioneer DVR-111D 1.29
2Dogs
Postby Wesociety on Sat Mar 15, 2008 12:06 am
Some burners are so crappy that you need to feed them 'premium' media in order to get a good burn. Premium media being Taiyo Yuden, Verbatim, etc.
