DVD bruning problem
DVD bruning problem
Postby thakurlokesh on Sat May 19, 2007 3:58 am
I have recently bought BENQ DW1800 DVD±R. When I try to burn any data in DVD disc using nero, it burns but give some error msg"error:cant write disc at once". When I insert that dvd disc again in DVD writer, it(dvd writer) unable to read the data in the Disc. When I try to write more data in disc, a error msg appears "not able to write data in an open disc". I could not write any DVD successfully since I have bought it. I have wasted 4-5 discs because of this error. Is the problem with DVD writer or DVD disc or Nero?
thakurlokesh
Postby Ian on Sat May 19, 2007 8:20 am
I would try other media. Usually this sort of thing is caused by unsupported or low quality discs.
Postby thakurlokesh on Sat May 19, 2007 11:53 am
Ian wrote:I would try other media. Usually this sort of thing is caused by unsupported or low quality discs.
I use writex DVD Discs. Are they not good? http://www.writex.net/
thakurlokesh
Postby Ian on Sat May 19, 2007 1:31 pm
Who's the actual manufacturer? MBI?
Postby Bhairav on Sun May 20, 2007 3:00 am
^Nopes. The ones I got were Plasmon, and REALLY low quality Plasmon :cry:
Lokesh.. do yourself a favour and get some good MBI Pro or Sony media.
Postby thakurlokesh on Sun May 20, 2007 1:22 pm
I have writex Disc. I also have doubt about writex. Writex is an indian company while BENQ is a Chinese company. So It could be the issue.
Moserbear is also and indian company so I would not buy it. Can someone tell me which DVD discs are of chinese companies?
thakurlokesh
Postby Wesociety on Sun May 20, 2007 5:12 pm
You don't want Chinese DVD media, most of it is crap quality. Get yourself some Sony (Made In Japan), Verbatim or Taiyo Yuden DVDR's...
Postby Bhairav on Sun May 20, 2007 10:15 pm
Wesociety wrote:You don't want Chinese DVD media, most of it is crap quality. Get yourself some Sony (Made In Japan), Verbatim or Taiyo Yuden DVDR's...
Only Verbs in India, unfortunately! This guy's logic is awesome though..
