DVD 16x PIONEER PROBLEMS
Postby dentarg on Thu Nov 28, 2002 8:17 am
Hi everyone,
I have a DVD 16x pioneer 116 and I got problems in the first startup because when I insert CD´s or DVD´s then autorun fails and if I open the explorer and browse to the unit then it says: there is a I/O problem and I can´t do nothing. :-?
This issue solves itself when I restart the computer again and all works ok.
So, wtf ! why I have to reboot my PC always two times in order to read my CD or DVD in my DVD unit. :evil: :cry:
Sometime I remembered all was ok, but now this is the problem I have.
My Pc consists of Windows 2000 professional with SP3 on a PIV 1.8 GHZ, 512MB.
Thanks all for the replies :wink:
dentarg
Postby cdrfreak2003 on Fri Nov 29, 2002 12:17 am
i have the same burner and never had a problem
cd-r freak
cdrfreak2003
Postby dentarg on Fri Nov 29, 2002 10:21 am
Well my DVD is Not a burner (only reads DVD and CD) and your reply don't solve my problem :cry:
:oops: :cry:
dentarg
Postby Han on Fri Nov 29, 2002 1:36 pm
Open Device Manager, delete the drive and its IDE channel. Right click on My Computer and choose Manage. Under Removable Storage - Physical Locations delete any CD/DVD drives. Reboot and let Windows detect devices. Check for UDMA settings in Device Manager... I hope that helped.
Han
CD-RW PiMP
Postby dentarg on Sun Dec 01, 2002 1:14 pm
Thanks Han for your reply.
I tried what you said me, but it didn´t work :cry:
Hope someone could help me :roll: :wink:
dentarg
Postby dentarg on Fri Dec 06, 2002 10:18 am
My problem still persists :cry: :cry:
Anyone who knows a solution, please post it :lol:
dentarg
Postby exo on Tue Dec 10, 2002 3:34 am
I have a pioneer 106-s and i just started getting that crazy i/o error a few days ago. I changed the atapi layer and unistalled everything, but it doesnt seem to do much.
BTW: running xp-pro sp1.
I updated its firmware ages ago, so i dont think that has anything to do with it.
exo
Postby dentarg on Wed Dec 11, 2002 6:30 pm
I have the I/O error at first startup with win 2000 SP3 and even with Windows XP Pro Sp1 :cry:
:oops: :cry:
dentarg
A DVD Dilemma
Postby NeilPeart on Thu Dec 12, 2002 12:05 am
Dentarg,
First ensure that the jumpers are correctly set and you are using the latest firmware. Here is a link for the Pioneer firmwares: http://www.pioneerelectronics.com/Pioneer/CDA/ServiceAndSupport/SelfHelpForIndList/1,1458,60~6020~6020600,00.html. Then make sure you have the latest chipset drivers and ensure they were installed correctly (check the secondary IDE channel's driver in the device manager). Also, try using a different IDE cable (a non-rounded, regular ATA cable just to rule out any other problems). Since both Windows XP and 2000 resulted in failures, the problem is most likely a hardware problem. Good luck.
Drives I Own:
Asus S520/A, Plextor UltraPlex 40TSi, Lite-on XJ-HD166S, Pioneer DVD-106S, Toshiba SD-M1712, Plextor PX-R820Ti, Plextor PX-W1210TS, Plextor Premium, Samsung SM-352B, Teac CD-W540E, Yamaha CRW-F1, Plextor PX-708A, Sony DRU-510A
NeilPeart
Postby dentarg on Sat Dec 14, 2002 8:20 am
NeilPeart thank for all the usefull info you posted.
I´ll try and tell you the results. :D
cya :)
dentarg
