Dual Layer problem in DVD machine
Postby daveiosys on Mon Sep 04, 2006 6:09 pm
Burned a movie to a TDK DVD +R DL disk - found it would not play on my DVD machine. ???? - Do DVD machines only play DVD -R DL disks or does it depend on the DVD machine? Thanks.
daveiosys
Postby Ian on Mon Sep 04, 2006 6:12 pm
It really depends on the machine. What you can try is setting the book type to DVD-ROM. This will usually get a player to read a DVD+R DL disc.
Reply to your post
Postby daveiosys on Mon Sep 04, 2006 6:22 pm
I do not know what I need to do to: set the book type to DVD-ROM
Please advise or point me to a link in one of the forums - Thank you.
daveiosys
Postby Scour on Mon Sep 04, 2006 6:37 pm
Which DVD-writer and software u use? Which DVD-player?
Postby Ian on Mon Sep 04, 2006 7:27 pm
If I remember right, he has a Plextor PX-712A. I think you have to use Plextools to set the booktype.
Postby daveiosys on Mon Sep 04, 2006 7:47 pm
I used a LG GSA-E10L to make the DVD +R DL.
Plextools XL Professional will change settings for my Plextor PX-712A but will not change settings for my LG GSA-E10L.
Any way to set the book type to DVD-ROM with Nero or Roxio?
Thanks.
daveiosys
Postby Ian on Mon Sep 04, 2006 8:16 pm
You should be able to set the book type with the GSA-E10L by using CD Speed (www.cdspeed2000.com).
Postby dolphinius_rex on Tue Sep 05, 2006 2:09 am
It might also be a quality issue... is TDK using Ritek DVD+RDL? if so, then it's probably right there.
Postby RJW on Tue Sep 05, 2006 4:45 am
TDK is ussing Ricohjpn D00 dual layer if I'm right.
If it's the media then try ussing verbatim/mitsubishi dual layer.
Postby dodecahedron on Tue Sep 05, 2006 6:10 am
daveiosys wrote:Any way to set the book type to DVD-ROM with Nero or Roxio?
in Nero you can set it in the Choose Recorder dialog. click the Options button.
i'm sure you can do it in Roxio software too but i'm not familiar with it.
Follow-Up
Postby daveiosys on Wed Sep 06, 2006 3:33 am
Accomplished conversion with NERO - Thanx.... Now my JVC & Sony DVD players will play my movie burned to DVD +R dual layer disk
daveiosys
