Dual DVD Recording with Sony DRU-500A and NEC ND-1100A
Postby Kennyshin on Sun Jan 26, 2003 2:21 pm
I received my I-O DATA 4x DVD+R writer, DVR ABN4P, which is an NEC ND-1100A yesterday.
I am right now burning a 2x DVD-R disk with Sony DRU-500A and a 2.4x DVD+RW disk with NEC ND-1100A simultaneously.
System Configuration
Athlon 1.33GHz CPU
Chaintech AMD-761 Motherboard
Crucial PC2100 DDR-SDRAM 512MB
Onboard ATA-100
Primary Master - HDD: Seagate Barracuda ATA IV 40GB
Primary Slave - none
Secondary Master - ODD: Sony DRU-500A
Secondary Slave - ODD: NEC ND-1100A
RaidTech Aralion ATA-100 4-channel PCI
Primary Master - HDD: Maxtor 5,400-RPM 100GB
Kennyshin
Postby glock20rocks on Sun Jan 26, 2003 4:00 pm
Cool! :)
I want a DVD burner :(
Come on Plextor, make a dual-format DVD burner!
Were the sources for the two dvd's on the same drive or different drives?
I tried burning two CDs at once but it didn't do too well (but then, I did have 'em both on the same channel, which explains everything. I hate being out of IDE connectors).
glock20rocks
Postby Bhairav on Sun Jan 26, 2003 11:50 pm
Wow... nice going Kennyshin!
What was the cpu usage when you burned the 2 discs simultaneously? Were you able to multitask easily?
Postby Kennyshin on Mon Jan 27, 2003 7:18 am
bhairavp wrote:Wow... nice going Kennyshin!
It was not very high but my system was lagging a lot even when burning one disc. Nothing to do with the performance of an Athlon 1.33GHz though.
The system was doing various other jobs.
I just posted it since this was the first time I tried dual DVD burning. The system needs to have a fresh OS installation. :)
Kennyshin
Postby Kennyshin on Mon Jan 27, 2003 7:21 am
glock20rocks wrote:Cool! :)
The same HDD.
HDD D: -> ODD E
HDD D: -> ODD G
It'll be much better with Serial ATA since the cable is so long and thin.
Kennyshin
Postby glock20rocks on Mon Jan 27, 2003 2:52 pm
Longer cables are always a plus. Better still, serial ATA is supposed to be better at multitasking with two drives on the same channel (more like SCSI). That'd certainly help SerialATA RAID performance.
glock20rocks
Postby Pradeep on Mon Jan 27, 2003 3:09 pm
Serial ATA defines one device per channel, there is no daisy chaining like IDE or SCSI.
Pradeep
