DRU-500A Verification Problems with Nero.
Postby xanra on Sun Nov 17, 2002 9:48 pm
Has anyone done write verify's when burning DVD-R's in Nero?
I don't usaully do a verify, but i noticed some weirdness in a DVD-R that i burned, a whole bunch of files weren't able to be read off the newly burnt DVD-R. So i've been verifying every disc that i burn now. It turns out that every DVD-R that I burn is bad. It says something like 375 files identical... 73 files inaccessable.
This is after it says that it has successfully burned the DVD-R. This only happens with DVD-R's, I wrote and verified a SONY DVD+RW. I'm using TDK 2x DVD-R. Has this happened to anyone else? I hope people have tried verifying there discs, or else were all in for a big surprise.
i'm using:
nero 5.5.9.17
dru500a firmware 1.0d
TDK DVD-R
SONY DVD+RW
xanra
Can't read data
Postby BBWoof on Tue Nov 19, 2002 1:43 am
I'm having something of the same problem. My DRU500 seems to write just fine, but if I put the disk back in it, it reads a bunch of files as bad. If I put the DVD in my DVD-ROM it seems to read fine.
Also, VCDEasy now doesn't recognize my ASPI as valid, and I've installed the latest ASPI layer from adaptec.
I'm runnin WinXP Pro on a Athlon XP 2100
Wish I could figure this one out.
BB
BBWoof
Postby sonyman on Tue Nov 19, 2002 1:58 am
I don't know about solving your problem, but I may be of some help. First of all, Install ASPI 4.60. It can be found on Adaptec's site under the Windows 95 downloads section.
-Scott
Gigabyte GA-8KNXP
Intel Pentium 4 3GHz
1024MB PC3700 DDR @400MHz CL2
ATI Radeon 9700 Pro
Sony DRU-500A
Lite-On LTR-52327S 52x32x52
sonyman
Postby cfitz on Tue Nov 19, 2002 2:28 am
Hi Scott,
Maybe you could educate me here. I've heard rumors that many have had trouble with versions 4.7+ of ASPI and that version 4.60 works better for them. Is that why you are suggesting installation of 4.60? My concern is that BBWoof is running XP, while you are suggesting a Windows 95 download. On the download page ( http://www.adaptec.com/worldwide/suppor ... aspi32.exe ) Adaptec states:
Do NOT install ASPI32.EXE with Windows 2000, Windows ME, Windows XP, Easy CD Creator 4.x, or with Windows Media Player 7.0. If you have one of these applications (or operating systems), you will be using a different aspi layer that will conflict with the one provided in this file.
Versions 4.70, 4.71 and 4.72 ( http://www.adaptec.com/worldwide/suppor ... /ASPI-4.70 ) claim to be compatible with XP, although under XP they must be installed via a batch file rather than through the ASPIINST.EXE installation executable:
For Windows XP, select Start - Run from the menu, and then the Browse button. Locate the INSTALL.BAT file in the directory the files extracted to and select the OPEN button. In the command box, add a space and either XP32 for Pentium I/II/III/IV processors or XP64 for Itanium processors. The command should look like: c:\adaptec\aspi\install.bat XP32 or c:\adaptec\aspi\install.bat XP64. Then select the OK button to run the XP installer.
BBWoof, what exactly does aspichk.exe show when you run it?
Postby sonyman on Tue Nov 19, 2002 2:58 am
That is correct cfitz. Many people are having major problems with Adaptecs 4.7* series ASPI drivers. I haven't had any issues with burning although one program I used couldn't even detect the 4.72 ASPI drivers. Some programs have a difficult time detecting the 4.72 drivers. The 4.60 drivers work fine with XP. The only problem I had was when I tried to revert back to 4.72 it wouldn't, so I simply manually deleted the 4.60 ASPI files and then reinstalled 4.72. It then worked fine. I installed 4.72 again because I wasn't having any problems with it (excluding the one flasher program) and I like to have the newest.
-Scott
Gigabyte GA-8KNXP
ATI Radeon 9700 Pro
Sony DRU-500A
sonyman
Postby cfitz on Tue Nov 19, 2002 3:05 am
So this is one of those cases where it isn't the officially recommended configuration, but it actually works better than the officially recommended configuration? It wouldn't be the first time...
Thanks Scott.
P.S. Here is a link to a page where ForceASPI can be found, in case the Adaptec 4.60 download doesn't work out:
http://www.cyrus.troy.btinternet.co.uk/downloads.htm
Postby sonyman on Tue Nov 19, 2002 3:07 am
Exactly. I do believe that 4.60 used to be used on XP, but when 4.7 was released, they removed 4.60 from the XP section and placed it in the one section in which it is the latest version, Windows 95.
-Scott
Gigabyte GA-8KNXP
ATI Radeon 9700 Pro
Sony DRU-500A
sonyman
maybe it is the ASPI
Postby xanra on Tue Nov 19, 2002 4:25 am
yeah, i'm using ASPI 4.71, but the nero InfoTool says my aspi configuration is installed and working properly. But i guess i should try to downgrade and test that.
Has everyone verified at least one of their DVR-R burns?
If never did a verify on my burn, i would have assumed that the burn worked fine.
xanra
Re: maybe it is the ASPI
Postby cfitz on Tue Nov 19, 2002 4:35 am
xanra wrote:But i guess i should try to downgrade and test that.
You could do that, although I don't think it will help. Nero uses its own ASPI layer, so changing out the Adaptec layer shouldn't have any effect on Nero. I'm afraid we have somewhat hijacked your thread and are addressing BBWoof's ASPI issue. Sorry. :oops:
Anyway, xanra, what type of DVD's are you burning? And which of the files are bad?
BBWoof, even though VCDEasy doesn't recognize your ASPI layer as being valid, does VCDEasy (or, rather, CDRDAO within VCDEasy) work?
Xanra and BBWoof, what are you using to verify the files?
Postby gianniz on Tue Nov 19, 2002 10:12 am
by any chance your using via hardware? like via chipset ... via chipset was renowned for corrupting data...
but i have only had few incidence where it failed with a04. it turned out to be shitty quality media.
gianniz
Verifying
Postby BBWoof on Wed Nov 20, 2002 12:04 am
I'm not using anything to verify. I've burned with both Nero and RecordNowMax, and burnt DVD's play fine in my standalone and my cheapy dvd-rom drive. But nothing reads in the SONY DRU500a.
And about CDRDAO, no, it wouldn't recognize the aspi when I had 4.7? installed. I used force aspi to reinstall 4.60, but it still doesn't read from the Sony. It's very irritating.
Should I maybe remove all the aspi dll files from my system and reinstall 4.60 from scratch.
I just completely wiped my system, and don't really want to do another complete install.
BB
BBWoof
verify
Postby xanra on Wed Nov 20, 2002 4:14 am
I'm using Nero to verify the burn, right after the burn is complete.
It's one of those checkboxes in the burn window.
I'm not using a VIA chipset either... It's an intel chipset.
The thing that is so puzzling, is that this only happens with DVD-R's...
I have successfully burned and verified a DVD+RW.
Could it be that i just purchased a bad batch of DVD-R's?
They're not crappy DVD-Rs, they're TDK 2x.
xanra
Postby cfitz on Wed Nov 20, 2002 4:51 am
BBWoof, I want to make one thing clear - the ASPI problem doesn't have anything to do with being unable to read DVD-R discs you burned in the Sony DRU500. XP (the OS itself) doesn't use ASPI to read from optical drives. The only thing we are trying to clear up with the ASPI investigation is your VCDEasy problem. And I'm still a little unclear on exactly what happens when you start VCDEasy. On the main window, do you see just note 1 as shown below, or both notes 1 and note 2?
Also, please open up a command prompt window, type the following, hit return and post what you see:
Code: Select all
sc query aspi32
BBWoof and xanra, I am tempted to say you are having media issues. If I understand correctly, the DVD discs you burn are readable in other drives, but only partially readable or not readable at all in the Sony DRU500. Do you have any trouble reading pressed CD and DVD media in the DRU500? Have either of you checked the files on the suspect DVD discs using a file verification program like MD5summer ( http://www.md5summer.org/ ) or CDCheck ( http://www.elpros.si/CDCheck/ ) Xanra, you have just had problems with one type and brand of media. What about you, BBWoof? Finally, have both of you thoroughly read Veff's media compatibility thread?
Postby VEFF on Wed Nov 20, 2002 12:03 pm
Note that most new burning programs have ASPI drivers built-in.
Only one or two even require you to have ASPI installed on your machine
as a whole.
I have the drivers installed, since they don't hurt, but most new burning programs don't even use the machine ones.
Burners only:
Pioneer DVR-115D
Pioneer DVR-111D
Plextor PX-716A TLA0304
Plextor PX-716A same TLA
LiteOn 52246S 52X CD-RW
LiteOn 52246S (another)
LiteOn 52327S 52X CD-RW
TDK 40X USB 2.0 CD-RW
TEAC CD-W540E 40X CD-RW
VEFF
Postby cfitz on Wed Nov 20, 2002 1:00 pm
VEFF wrote:Only one or two even require you to have ASPI installed on your machine as a whole.
CDRDAO (as incorporated into VCDEasy) is one such program that requires an external ASPI layer. However, as you and I have both reiterated, ASPI isn't the cause of the DVD reading problems being reported here.
The only reason ASPI got into this whole discussion is because BBWoof is reporting trouble with VCDEasy. In my last post I tried to clarify and separate the issues. Maybe BBWoof should spawn a new thread in a more appropriate forum (General Software Questions, perhaps?) for his VCDEasy problems. I will be happy to move my ASPI-related replies to that thread if he chooses to do so.
Postby sonyman on Wed Nov 20, 2002 8:52 pm
VEFF wrote:Note that most new burning programs have ASPI drivers built-in.
as a whole.
Some firmware flashing programs still do require that one has an external ASPI layer installed.
-Scott
Gigabyte GA-8KNXP
ATI Radeon 9700 Pro
Sony DRU-500A
sonyman
help
Postby dogdivine on Fri Nov 29, 2002 12:49 pm
Hi,
does anyone know how can't I see the sony dru 500a in nero....
I have a LG 40x12x40 and a Sony dru500a in my PC but when I go to select a recorder in Nero just give the LG how can't I put both?
DogDivine®
just for fun !!!!!!!!!!!!!!!!
dogdivine
