dr4-a dual burner problem
Postby barneyboy on Wed May 12, 2004 3:28 am
Hello all,
Ive been looking around your board and i think you clever lot might be able to sort out a little problem i have...be gentle im new!
O.K, I have updated my system and have noticed that my dvd burner has been getting more and more unstable every time i use it for dvd copying using Nero 6 Ultra. Finally last night it stopped playing all dvd disks and freezes the system so you have to reboot. I burns and reads cdr media fine. I have updated firmware and cleaned the drive and checked nero but it remains the same. Anybody got any ideas?
My system is as follows;
P4 2.80c, Asus P4v800x, msi5600xt 128,512k 3200 ddr400,Sata 120g HDD, Windows XP.
The drive is set to DMA and is master on primary IDE, I have cdr burner on secondary ide set to master.
Can anyone help??
barneyboy
Postby barneyboy on Thu May 13, 2004 7:25 am
43 views and not 1 suggestion! :roll:
barneyboy
Postby CDRecorder on Thu May 13, 2004 11:24 am
Welcome to CDRLabs! :D
From the symptoms you describe, I think that the DVD burner probably needs to be replaced. If it's still under warranty, I recommend that you RMA it.
Postby Ian on Thu May 13, 2004 12:55 pm
Have you tried another IDE cable? Have you installed any new software lately? How about another computer?
