Am I doing something wrong with my DVD burner ?
Postby gomcse on Fri Jun 20, 2003 1:07 pm
Hi folks,
Just installed my Pioneer DVR-A05 DVD burner onto my PC. Everything is except when I do a full erase on my DVD-RW (Princo DVD-RW) I either getting erase failure or after a full erase, my DVD burner cannot access that particular DVD-RW any more.
FYI, if I just do the quick erase, no problem.
May I know how can I fix the problem ?
Please kindly advise.
gomcse
Postby burninfool on Fri Jun 20, 2003 2:50 pm
First of all did you reboot and try to access?Secondly have you upgraded the firmware to v 1.33?Princo media is garbage use Taiyo Yuden,Mitsubishi,Ritek or Optodisc.
http://wwwbsc.pioneer.co.jp/product-e/ibs/device_e/dev00001r_e.html#firmware1
Postby gomcse on Fri Jun 20, 2003 4:14 pm
Hello burninfool
U are right. Might be I should update the firmware the latest version. Of course, since I only have two Princeo DVD-RW, so I am planning to get Verbatim DVD-RW.
Do you think Verbatim is a good brand name for DVD-RW ??
It is ashame that I cannot get Taiyo Yuden,Mitsubishi,Ritek or Optodisc DVD-RW in Vancouver.
Please advise.
Have a nice weekend, man !
gomcse
Postby burninfool on Fri Jun 20, 2003 6:34 pm
gomcse wrote:Do you think Verbatim is a good brand name for DVD-RW ??
Yes it is and Verbatim is usually made by Mitsubishi(sometimes CMC).
Check out these sites(they ship to Canada):
www.allmediaoutlet.com
www.buy.com
www.rima.com
Postby gomcse on Fri Jun 20, 2003 6:44 pm
Hello burninfool
thanks again for your info and I will check out those 3 sites.
Have a nice weekend.
gomcse
