Does Nero lock DVD write speeds @ media's rated speed?
Postby dmbfan36_23 on Mon Sep 15, 2003 10:42 am
I have a Sony DRU500A running 2.0F (which supports 4x DVD+/-R burning)... I've got a bunch of Verbatim 2.4x DVD+Rs & a few Memorex 2.4x + and - R discs... When I try to burn a new DVD the compilation window in Nero 6 doesn't display anyting but 2.4x for burn speeds... the drop down doesn't include a 4x option.... Seeing as I still have like 40 blank DVDs I haven't bought any 4x media yet, just curious if this is the expected behavior or not? I was hoping to try a 4x burn on some of the Verbatim discs....
dmbfan36_23
Postby VEFF on Mon Sep 15, 2003 12:02 pm
I know the burner can tell the software what to set the speed to, based on the firmware table; for example the Plextor lets you burn at 8X on 4X media with Nero and Stomp, among others.
I assume that if a given disc isn't in the firmware's media table/list, then the software probably defaults to the discs's rated speed, as set by the manufacturer.
In other words, I think the DRU-500A is limiting the burn speed for that particular media, to its rated speed.
I am pretty sure that Nero is not going to limit the burn speed, unless
the burner doesn't pass Nero any instructions on what speed to default to.
This is why Nero and Stomp will allow you to successfully burn some brands of 4X +R media at 8X. The burner is telling Nero what to set the maximum speed to.
I am not an expert, and these are just my own observations and assumptions.
Burners only:
Pioneer DVR-115D
Pioneer DVR-111D
Plextor PX-716A TLA0304
Plextor PX-716A same TLA
LiteOn 52246S 52X CD-RW
LiteOn 52246S (another)
LiteOn 52327S 52X CD-RW
TDK 40X USB 2.0 CD-RW
TEAC CD-W540E 40X CD-RW
VEFF
