DMA - samsung 352b combo + sony dr 500ax dvd burner
Postby dellboy on Mon Jun 16, 2003 2:52 pm
HI,
TECHNICAL QUESTION.
COULD SOMEBODY HELP,
I WANTED TO KNOW IF I SHOULD ENABLE THE * DMA*
SETTING IN THE DRIVER SETTINGS IN (DEVICES) FOR THE ABOVE TWO
UNITS, OR ONE OR THE OTHER.
THE SAMSUNG IS SET AS MASTER
THE SONY IS SET AS SLAVE
I USE THE 52 SPEED SAMSUNG COMBO AS THE MAIN DRIVE.
dellboy
Postby Ian on Mon Jun 16, 2003 3:11 pm
1. TURN OFF THE CAPS RIGHT NOW
2. Yes, you should enable DMA for both drives. It will help your performance immensely.
