dma problems caused broken ide-driver
Postby ausgang on Thu Jan 11, 2007 4:33 pm
i got transfer mode problems with my SONY DVD+-RW DW-Q58A
inspection in the device manager showed the following:
primary ide-device 0 current transfer mode is at "ultra dma mode 5"
primary ide-device 1 current transfer mode is at "not available"
secondary ide-device 0 WAS at "pio"
secondary ide-device 1 current transfer mode was at "not available"
i thought that my dvd-drive is secondary-ide; device 0;
although "dma, if available" was selected, the channel only had "pio".
i hoped to fix it with this thread:
first, i set the channel to "pio" - reboot - then i set the channel again to "dma, if available" - reboot - same shit as before, nothing changed.
then i deleted the secondary ide - reboot - another problem occured :sad: windows can't reinstall the driver for the secondary ide. each reboot i am told, that new hardware is found (the 2nd ide), but the drivers could not be installed (neither automatically nor manual method functioned).
i am using xp pro sp2 (all updates installed).
now there is a yellow sign on the ide-channel in my device manager. #-o
and now the curiosity: i can see and open data on my dvd drive in windows-explorer ....
don't know what to do ... anybody got an idea?
thanks in advance
ausgang
Postby Ian on Thu Jan 11, 2007 4:40 pm
Are you using the Microsoft IDE drivers or ones for your motherboard (VIA, Nvidia, etc)?
Postby Scour on Sat Jan 13, 2007 7:50 pm
Deinstall the IDE-port and reinstall MS Standard-IDE-drivers and make reboot
Postby ausgang on Sun Jan 14, 2007 6:52 am
the chaotic situation endend up in re-installing windows. when i tried to go back to a system-restore-point restarting ended up in blue screen. also repairing via windows cd didn't do the job. i hate it when such things happen. thanks anyway for the suggestions. after re-installing every ide-channel is at dma transfer.
ausgang
